120
OxygenOS Android 11 Open Beta 2 for OnePlus 6/6T
  1. Ansuman_B
    Froyo Jul 29, 2021
  2. Max.Mar
    Jelly Bean Jul 29, 2021
    Max.Mar , Jul 29, 2021 :
    Everything comes to an end.. but that doesn't mean one should start weeping over everything rather enjoy till you have it.
  3. Max.Mar
    No such issues. Try clean flash.
  4. Federico Martin
    Gingerbread Jul 29, 2021
  5. Max.Mar
    Doesn't work. And it won't work because in Android 11 is based on A& B partitions. Cache partition won't help much.
  6. Max.Mar
    Hope you clean flashed and if not than that's your issue.
  7. Max.Mar
    Can't say anything about 6T but 6 does.
    D.Sai Suhail Baba and Master_TC like this.
  8. chielmi
    chielmi , Jul 29, 2021 :
    Both issues I had with Beta 1 (gmail not showing notifications, screen saturation) have been fixed with Beta 2. I use a 6T.
    D.Sai Suhail Baba likes this.
  9. pulkitv12
    Cupcake Jul 29, 2021
    pulkitv12 , via OnePlus 6 , Jul 29, 2021 :
    Same for me, a yellowish/greenish tint while vision comfort is on.
    And its not at all comfortable to eyes. Tried all display settings, wiping cache but no luck.
    Mine is op6
  10. DaOldMan
    DaOldMan , Jul 29, 2021 :
    Guys do you get those weird suggestions in the quick share menu (the one that appears when you press any share button)? I get people on the first line I didn't chat with in ages. On contrary those I share things a lot never appear. It's just useless. Yes, I can pin apps but not my frequent contacts. When it used to work it's very handy. Now I always need to enter the app and share to a contact inside that app. If someone knows a fix to this I will be happy to know.
  11. pulkitv12
    After android 11 open beta 2, a yellowish/greenish tint is there on display while vision comfort is on.
  12. GauravaRai
    Honeycomb Jul 29, 2021
    GauravaRai , via OnePlus 6 , Jul 29, 2021 :
    Not just lagging. Its lagging like hell. Only 15-20 fps at lowest graphic settings.
  13. Z1612812270490
    Donut Jul 29, 2021
  14. freeshared
    freeshared , Jul 29, 2021 :
    wiping data/cache/factory reset won't help here,coz the issue is due to bad "colour space" management,which is kernel level function.
    so it can only be solved by an update from op
    S1533210894137 likes this.
  15. pulkitv12
    Oh okay. Hope OnePlus addresses that in the next build.
    Btw, thanks for quick response.
  16. E1623104392189
    Donut Jul 29, 2021
    Suraj1378 and GauravaRai like this.
  17. nastasedan
    Froyo Jul 29, 2021
    m5devil likes this.
  18. E1571515252028 likes this.
  19. Caomhin
    OnePlus 9 Series Expert Community Expert Jul 29, 2021
    Caomhin , via OnePlus 9 Pro , Jul 29, 2021 :
    A & B partitions true, and yet for some reason it can work at times. Strange that 👍
  20. GauravaRai
    I knew it will not work. Wiping cache partition is 24cr pure gold gimmick idea. Btw I'm also confirming that after wiping cache partition neither the turmeric feel display color is reduced nor PUBG aka BGMI lag is reduced. This completely ruined update.
