106
OxygenOS Android 11 Open Beta 3 for OnePlus 6/6T
  1. Bharath reddy k
    Cupcake Aug 10, 2021
    Bharath reddy k , via OnePlus 6T , Aug 10, 2021 :
    Notification pannel is not opening while in game mode
    signals are getting up and down while in driving
    android auto is not working properly
    while charging launcher is closing frequently
    Mainly network issue
    YouTube full mode is not working properly
  2. Abhishek.001
    Honeycomb Aug 10, 2021
    Abhishek.001 , via OnePlus 6T , Aug 10, 2021 :
    You can use oxygen Updater application from play store
    Or
    Download and install Roll back file in beta 1 post
    And
    install beta 1 OS 11
  3. RajulaRReddy
    Donut Aug 10, 2021
    RajulaRReddy , via OnePlus 6 , Aug 10, 2021 :
    Vision comfort mode is working strangely, after we unlocked then it is taking 4 to 5 seconds time to apply vision comfort mode. Oneplus team please fix that.
  4. Auristic
    Lollipop Aug 10, 2021
    ItsRavi25 likes this.
  5. Juanmafr
  6. Basudev7
    Gingerbread Aug 10, 2021
    K1577555224305 likes this.
  7. DaOldMan
  8. Walier0447
    Walier0447 , via OnePlus 6T , Aug 10, 2021 :
    I think theres lot of bugs and lag issues in beta 2 update , the camera issue , games lag issues , mobile battery issues , etc
    So I just went back to Android 10 now iam feeling good .
  9. Yuvi1330
  10. C1624788922607
  11. SIDD7411
  12. Phle
  13. ashimregme
  14. D_24
    D_24 , via OnePlus 6T , Aug 10, 2021 :
    Those who are having problems in BGMI/PUBG, can you try to modify the 'game driver preferences' in developer options & see if it makes any changes or not?
  15. mallu.achayan
  16. GauravaRai
    GauravaRai , via OnePlus 6 , Aug 10, 2021 :
    Because if it showed numbers, level of OnePlus treachery in name of cpu throttling will get exposed.
  17. GauravaRai
    Don't suggest if you didn't try.. btw it has no effect in frame drops.
