103
OxygenOS Android 11 Open Beta 3 for OnePlus 6/6T
  1. MahendarTinku
    Eclair Aug 9, 2021
  2. Caomhin
    OnePlus 9 Series Expert Community Expert Aug 9, 2021
    Caomhin , Aug 9, 2021 :
    No, please read the 1st post. Its for OnePlus 6 & 6T totally different phone and hardware.
  3. Caomhin
    Caomhin , via OnePlus 9 Pro , Aug 9, 2021 :
    As Beta testers, testing Beta software, have you run through one full charge cycle and also restarted the phone after that. As this Beta 3 software was only released an hour ago.
    Then run BGMI and see if it improves after the steps as mentioned above. This is all basic information that most Beta testers would know.
    If still happening, then give Feedback to the Developers in the links provided in the first post. Beta software can be unstable at times, and the more feedback given the better the next version can be. But you would know all this anyway, as I am sure you read the entire first post before trying out software una testing environment. 👍
    Tom886, rHITkM., ItsRavi25 and 3 others like this.
  4. Phle
    Cupcake Aug 9, 2021
    MALU8484 likes this.
  5. ParsleyUA
    Cupcake Aug 9, 2021
  6. A1564450385122
    Eclair Aug 9, 2021
    A1564450385122 , via OnePlus 6T , Aug 9, 2021 :
    Restart or reinstall doesn't help. Let me post the updates after 1 full charge cycle.
  7. Caomhin
    You must have a network provider who provides the Volte/VoWifi service on your mobile plan.
    The VoLTE/VoWifi settings will be in your Sim & Network settings, if its not showing and you have a Network provider that supports it as well as a good 4G LTE signal then try the following to see if this will enable it.
    This is for all OP phones, however it discuses the 8 Series, but it should apply to any series as the protocols are the same.
    [GUIDE] Enable VoLTE & VoWiFi on all devices NO ROOT.
    https://forum.xda-developers.com/on...nable-volte-vowifi-devices-root-t4105817/amp/
    Log Kit 1.0
    https://www.apkmirror.com/apk/onepl...ase/onepluslogkit-1-0-2-android-apk-download/
    There are newer versions but I would suggest trying this with the details provided on XDA.
    y0uri, Tom886, Alessandro_R. and 3 others like this.
  8. Archit@123
    Honeycomb Aug 9, 2021
    Archit@123 , via OnePlus 6T , Aug 9, 2021 :
    Reinstall game and check
  9. W1611151803963
    Cupcake Aug 9, 2021
    W1611151803963 , via OnePlus 6T , Aug 9, 2021 :
    Hello I need a help I when ever I use my OnePlus 6t it's always freeze display for 5/10 Sec I don't know why it's happen pls need. Help what to do ? 😔😔
    Darpan_Yashlaha and SandR12 like this.
  10. Master_TC
    KitKat Aug 9, 2021
    Master_TC , Aug 9, 2021 :
    VoLTE Germany O2 not working.
    Reported over feedback.
  11. A1564450385122
    Eclair Aug 9, 2021
    Reinstalled the game , restarted the phone. Still the same frame lag.
    Interesting thing is game was very smooth in OB1
  12. Archit@123
    They are throttling performance to reduce heat and battery usage.
  13. A1564450385122
    Eclair Aug 9, 2021
    Maybe.. but haven't faced any such heating issues in my OP6T. It'll be good if they fix this BGMI lag issue instead of battery drain
  14. Thamarainathan
    Cupcake Aug 9, 2021
    Pallab_Sarker likes this.
  15. nastasedan
    Froyo Aug 9, 2021
    nastasedan , Aug 9, 2021 :
    Gmail notifications issue is still here in OB 3! Come on Oneplus, fix this issue!
  16. Master_TC
    KitKat Aug 9, 2021
    No ETA.
    I think after one more open beta we will get stable.
    Abhishek1945, Caomhin and Auristic like this.
  17. Master_TC
    KitKat Aug 9, 2021
    Please use the feedback function mentioned in the first post.
    I have read many times on open beta 2, that after a factory reset the bug is gone. Perhaps you can try.
  18. nastasedan
    Froyo Aug 9, 2021
    nastasedan , via OnePlus 6 , Aug 9, 2021 :
    I did a factory reset after the first Open Beta. Should I try another one?
    #38
  19. GauravaRai
    GauravaRai , via OnePlus 6 , Aug 9, 2021 :
    As I read here in a number of post with PUBG/BGMI lags and no frame drop improvement. So simply 🖕this OnePlus attitude and update.
    #39
    PATIL9508 and Suraj1378 like this.
  20. Master_TC
    KitKat Aug 9, 2021
    If you want yes.
    After factory reset setup up your phone only with the most needed apps and gmail. Don't change to much in the settings. Let all in factory modus and let's see.
    #40
    Caomhin, Auristic and nastasedan like this.
