106
OxygenOS Android 11 Open Beta 3 for OnePlus 6/6T
  1. Ashish7194
    Cupcake Aug 11, 2021
  2. coxik
  3. Dr.S.NANDAKUMAR likes this.
  4. ItsRavi25
    Jelly Bean Aug 11, 2021
    Auristic likes this.
  5. coxik
    coxik , via OnePlus 6T , Aug 11, 2021 :
    With beta 3, we will get updates to stable or need to go down to 10
  6. ItsRavi25
    ItsRavi25 , via OnePlus 6T , Aug 11, 2021 :
    As both the beta 3 and stable build date is same, so you have go down to A10 and then install the latest.
  7. B1558624431099
  8. prasanthhook
    Eclair Aug 11, 2021
  9. ItsRavi25
    Stable version released, install the latest stable your problem will solve 😇
  10. prasanthhook
    Eclair Aug 11, 2021
    prasanthhook , via OnePlus 6 , Aug 11, 2021 :
    How to rollback stable version..pls help me . Should I download the. Stable version package and just simply install it right? Whether I have a data loss ?
  11. ItsRavi25
    Follow the thread all procedures and file links are there in the thread
    All for how to rollback
    Thanks to @ironass
    https://forums.oneplus.com/threads/roll-back-to-stock-android-9-or-10.1215079/
    Yes if rollback there will be data loss, it's advise to always do backup.😇
    Yes, and many others already installed and using it
    Paulj2703 and ironass like this.
  12. prasanthhook
    Eclair Aug 11, 2021
  13. prasanthhook
    Eclair Aug 11, 2021
  14. K1577555224305
    Ice Cream Sandwich Aug 11, 2021
    K1577555224305 , Aug 11, 2021 :
    I think after the next stable update you can directly switch to 11 by putting it in the root of internal storage.
    But you will have to wait for a month or so maybe less.
    Paulj2703 likes this.
  15. K1577555224305
    You will have to wait for the next stable release of A11 then only you can move to A11 stable or else wipe install A10 then A11.
    I would personally suggest to wait and use Ob3 for now.
    AbhinavJamwal likes this.
  16. A1564450385122
    Eclair Aug 11, 2021
    A1564450385122 , via OnePlus 6T , Aug 11, 2021 :
    So finally a solution for BGMI LAG. Once you're in OB3, just do a reset.
    Settings->system->reset options->delete all data (factory reset)
    Then after resetting, make sure play store apps are all upto date.
    Then start BGMI. You will feel like playing in a 90FPS device.
    K1577555224305 likes this.
  17. B1558624431099
    B1558624431099 , via OnePlus 6T , Aug 11, 2021 :
    What's OB3
  18. A1564450385122
    Eclair Aug 11, 2021
  19. B1558624431099
    You said we have to do factory reset.... It means it will wipe all data... Right..?
