881
OxygenOS based on Android 10 Incoming!
  1. Gsus83
    Eclair Oct 19, 2019
  2. matekarjayesh
    Cupcake Oct 19, 2019
    matekarjayesh , Oct 19, 2019 :
    18 Oct 2019, I updated my Oneplus 7 to android 10 (system update). Everything seemed smooth while downloading and installing but now I'm facing a strange and annoying issue, I'm not able to set ringtone. NOT EVEN system's default OnePlus ringtone. Yet to encounter other issues. If someone faced similar issue pl suggest!
  3. Gsus83
    Eclair Oct 19, 2019
  4. X1571486978925
  5. I1569509998750
  6. matekarjayesh
    on my OP 7, after updating to android 10, I have some strange ringtone, I can't change it, not even to OnePlus's default one.
  7. Russky100
    Eclair Oct 19, 2019
    Russky100 , via OnePlus 7 Pro , Oct 19, 2019 :
    Now cleared phone cache a second time and my phone is now working correctly...
    Ingoing and outgoing calls seem to be fine... Battery has improved and is now on par with the old system (good but not great).
    All other apps and system processes seem to be working as usual.
    Hope this helps?
  8. Z1568632652881
  9. Prashanth3912
    Donut Oct 19, 2019
  10. herohl
    Froyo Oct 19, 2019
  11. Sandeepbht96
  12. A1520395416267
  13. Pushpendra Singh Thakur
  14. Pushpendra Singh Thakur
    Pushpendra Singh Thakur , Oct 19, 2019 :
    Also, the side swipe (when side swipe gesture is off) is not working properly for opening hidden apps. A bug specific to oneplus I guess?
  15. dev4life
    Eclair Oct 19, 2019
    dev4life , Oct 19, 2019 :
    I got Android 10 update on my GM1901
  16. bocapxam2195
    bocapxam2195 , Oct 19, 2019 :
    i using Android 10 for week now, updated by Oxygen Updater. feel like something I don't like at this version but can't really tell
  17. Prashantyv
    Prashantyv , Oct 19, 2019 :
    Bugs in Oneplus 7 android 10.0.1 update :
    1) sometimes, once we go out of range of. WiFi, the data network doesn't switch on. Even after turning it on /off(wifi/data network). Have to use airplane mode to make it work.
    2) In games(gaming mode or not), in pubg/pubg lite, it shows message that game won't work in data mode, even after allowing app permission to use data network. I couldn't find any other setting to make it work on data.
    3) Random freezing of gallery/apps, very annoying. Have to quit app and restart.
    4)Open links/apps with shows 'system name' of apps
  18. JmcRepair33
    Ice Cream Sandwich Oct 19, 2019
    JmcRepair33 , Oct 19, 2019 :
    Na lol i will get the Newer phone. Thanks For trying to advise me though. Always with the latest and greatest from Oneplus devices
    Santoshtheone likes this.
  19. JmcRepair33
    The customization menu lol Mostly inetrnal fixes and the update of android 10
