796
OxygenOS based on Android 10 Incoming!
  1. W1571658124410
    Cupcake Oct 21, 2019
    W1571658124410 , Oct 21, 2019 :
    After update for anroid 10 , i am faceing some problems like i am unable to set any ringtone whenever there is any incoming call a dome sound ringtone is ringing no matter what is set in my ringtone.
  2. J1571658669173
    J1571658669173 , Oct 21, 2019 :
    7 pro user here, still didn't receive my update, my friend using 7 received it and showing off. What's taking so long?
  3. akashdutta700
    akashdutta700 , Oct 21, 2019 :
    phone is getting slow since I updated to Android 10.no game is working..even pubg is not opening...
    irizkhan007 likes this.
  4. Hariraghav
    Hariraghav , via OnePlus 7 Pro , Oct 21, 2019 :
    In have update my OnePlus 7 pro to 10.0.1. But the phone got slowed down. Even unlocking with the fingerprint scanner got a bit slower. The entire phone is bit slow and sluggish after the OS update. Really disappointing. OnePlus needs to fix this.
  5. O1537217666062
    wolfi135 and irizkhan007 like this.
  6. sekanderdany
    sekanderdany , via OnePlus 7 Pro , Oct 21, 2019 :
    I'm using OP7pro and after the Oxygen OS 10.0.1.GM21AA update my apps are crashing continuously after every 1/2 minute. specially happening while I use keyboard. I'm using Gboard. any solution or rollback option?
  7. kashyup88
    O1537217666062 likes this.
  8. Jungmanoj
    K1570390384754 likes this.
  9. O1537217666062
    O1537217666062 , Oct 21, 2019 :
    OS 10.0.1 the worse is ever. Better tested before release dear OxygenOS developer's. Apps crushing and not being able to use are the worse ever.
  10. I1570806553551
  11. K1539044134684
  12. bmharsha
  13. B1571668432094
    B1571668432094 , via OnePlus 7 Pro , Oct 21, 2019 :
    Hi guys after I updated the much awaited Oxygen 10, I started playing Call of Duty Mobile and it started to crash multiple times during game play. never happened before but this is the issue I'm facing.
  14. K1570390384754
    K1570390384754 , via OnePlus 7 Pro , Oct 21, 2019 :
    after I get the oxygen update 10 my oneplus 7pro is not supporting the wrap charging and some bugs also.. did any one have a problem for wrap charging after the update please comment or report it please.. what should I do
  15. K1570390384754
    my onepus 7pro now not supporting wrap charging after the update
  16. K1570390384754
  17. K1570390384754
  18. P1571671725393
  19. pigex
    pigex , via OnePlus 7 Pro , Oct 21, 2019 :
    Hi, I like the update so far but I have thus big regarding gestures. I have selected one plus bottom gestures but after unlock there are those corner symbols at the bottom that are part of the Google gestures. The phone then thanks that those gesture buttons are there (pill and corner buttons) and when typing there is an empty space for them under the keyboard. Screen shot here https://imgur.com/a/KZpy2M6
    P. S. It is the same with other keyboards, not just Fleksy.
    Thanks,
    Kuba
    F1555175675655 likes this.
  20. Eightfinity
