796
OxygenOS based on Android 10 Incoming!
  1. Marcel burns
    Eclair Oct 22, 2019
    Marcel burns , via OnePlus 7 Pro , Oct 22, 2019 :
    still some issues, plug my phone into my car for Android auto etc..... when I plug it put again it changes my display and it changes the icon packs as well so I could have circle to start with then changes to squares and dark mode is enabled.
  2. K1570686304118
    Cupcake Oct 22, 2019
    K1570686304118 , Oct 22, 2019 :
    What the hell.. I am facing network issues after updates. Search option is only searching the applications. Previously it will search complete phone like Downloads etc.
  3. AndersChristoffersen
  4. Jay Vijay
    Jay Vijay , Oct 22, 2019 :
    What's app is not showing pop up feature with this app .very bad. need to restore it
  5. Mr._Stark
    Donut Oct 22, 2019
  6. D€√!L
    D€√!L , Oct 22, 2019 :
    i am a 7 pro user and after updating to android 10 i m not able to play games like pubg ,cod, as the fnatic mode is not working properly.Even after switching to fnatic mode my ping in game fluctuates from 80 - 300,whereas before the update it was below 60 when i switch to fnatic mode.And this problem is constant no matter i use wifi or mobile network.
    plz help and reply as soon as possible for the solution.
  7. Shresth400
  8. hoosieradam
    Froyo Oct 22, 2019
  9. D.Sai Suhail Baba
    Froyo Oct 22, 2019
    D.Sai Suhail Baba , Oct 22, 2019 :
    Are you facing any bug issues and app crashing issues
  10. vigneshmiller
    Gingerbread Oct 22, 2019
    vigneshmiller , via OnePlus 6 , Oct 22, 2019 :
    All apps are working fine but file managed keeps crashing when I try to cut and move a file. Then I downloaded and installed the latest version from apkmirror website and now everything works fine.
  11. B1571746349705
    B1571746349705 , Oct 22, 2019 :
    hello sir this question is for everyone I would be thankful if you answer it. How can I create an app folder in the app drawer screen?
  12. N1537702527127
  13. iamvsv
    iamvsv , Oct 22, 2019 :
    Facing lots of problem in OS 10 . Apps don't work properly. Hope you'll do something about it.
  14. F_Nithin_Dey_Kjkc
    F_Nithin_Dey_Kjkc , Oct 22, 2019 :
    after updating android 10 is my one plus 7 my worse experience the phone get hang time to WhatsApp stop working
  15. G1541338527937
    G1541338527937 , Oct 22, 2019 :
    I've been experiencing "auto rotate issues" after the android 10 update on my OnePlus 6. It doesn't rotate to landscape most of the times and when it does, it doesn't move back to portrait when trying. Is is just me facing this problem?
  16. SunilSahani
  17. F_Mazin_M_Merza_EDiT
    Donut Oct 22, 2019
    G_Aled_Yag_FWVH likes this.
  18. S1571753688100
    S1571753688100 , Oct 22, 2019 :
    Hello team, the latest update has slowed down my phone. cannot use watsapp while on a video call. the overall responsiveness has decreased. Please can these be fixed ASAP.
  19. M1571755279975
    M1571755279975 , Oct 22, 2019 :
    some problems in android 10..
    1.. gyroscope problem
    2..back key problem
    so how to solve gyroscope problem in my phone
  20. E1570793934402
