843
OxygenOS based on Android 10 Incoming!
  1. Federico Prencipe
    Gingerbread Dec 7, 2019
    Federico Prencipe , Dec 7, 2019 :
    What phone are you using?
    Even if now a lot of phones have problems: 7, 7 Pro, 7t, 7t pro, 6t...literally every phone with Android 10 has problems
  2. Paul_Cherian_
    Cupcake Dec 7, 2019
  3. Paccman
    Froyo Dec 7, 2019
    Paccman , via OnePlus 6T , Dec 7, 2019 :
    If anyone updated to the earlier version of Android 10 and had problems with connecting media through Bluetooth to the car, can you confirm that Bluetooth media works with your car on Android 10.01
  4. iamrj
    iamrj , Dec 7, 2019 :
    Go to Settings
    Click on apps & notifications
    See all apps
    Search bluetooth
    Show system apps
    Storage & cache
    Clear storage , clear cache
    reboot
    try this?
  5. Paccman
    Froyo Dec 7, 2019
    I did that when I first upgraded, didn't work, went back to Android 9. I will wait until I get someone who had the same problem confirm that 10.01 resolves this
  6. Rameezsyed
    Cupcake Dec 7, 2019
  7. D1561291266358
    Cupcake Dec 7, 2019
  8. F1575780830186
    Cupcake Dec 8, 2019
    F1575780830186 , Dec 8, 2019 :
    My notch from below has been cut out and I'm mot liking it.. Overall good but how do I resolve this.. I'm using one ➕ 6
  9. Abhishek_Singh_2
    Gingerbread Dec 8, 2019
  10. Federico Prencipe
    Federico Prencipe , Dec 8, 2019 :
    That's a Google "option" in Android 10, this is a well knowk fact, nobody can do anything, it's up to Google...
  11. Federico Prencipe
    It's better you don't have It, trust me, have you red all the posts complaining about Android 10??
    F_Abhishek_Singh_wKkC likes this.
  12. Federico Prencipe
    Well knowk issue of Android 10, everybody knows it, including OP, I hope they are working on it but on my 7 Pro it's been months since Android 10 was released and still not working fine...
  13. F1575780830186
    Cupcake Dec 8, 2019
    Sad.... It was better before then.. As it is an inch cut out from below and full screen from above, hope there is a solution in the next update and that happens soon
  14. Federico Prencipe
    I also have a bar under the keybord, it's 8/9mm of wasted space but if memory serves is there for Google gestures (the new ones that have the back from the sides of the screen) and you have it also if you don't use those gestures.
    Luckily having a 7 Pro I have full screen display and don't have the problem with the notch.
    There are some restriction by Google and since Google own Andorid this is the situation
  15. F1575780830186
    Cupcake Dec 8, 2019
    Seriously, instead of resolving it 7 Pro is being promoted
    Hahaha... I'm happy with my One ➕ 6 but do not compel me to change it as this cut out is irritating it was better before
  16. Navafpp
    Froyo Dec 9, 2019
  17. RAP1+
    Cupcake Dec 9, 2019
    Shay+ and Paul_Cherian_ like this.
  18. G_vishwas_bhardwaj_Vwsb , via OnePlus 7 , Dec 9, 2019 :
    my one plus 7 gets hang while using whats app and facebook.
    i cant send images from gallery and camera. but sometimes it goes through. kindly look into this matter and revert back with the solution.
  19. G1575883452791
    Cupcake Dec 9, 2019
    G1575883452791 , via OnePlus 6 , Dec 9, 2019 :
    My friend and i have bought oneplus 6, i bought it first and after few months he bought the same phone. He has got Android 10 update but i haven't, why is that so. [e]1f620[/e]
    Shay+ likes this.
  20. MaggieQueen25
    Cupcake Dec 9, 2019
    MaggieQueen25 , Dec 9, 2019 :
    After the OS10 update notification sounds are not working.. all the notification sounds are giving same sound
    F1575780830186 likes this.
