882
OxygenOS based on Android 10 Incoming!
  1. vijayveer
    Cupcake Mar 7, 2020
  2. ShuhebR
    Cupcake Mar 7, 2020
  3. fsinsu8
    Cupcake Mar 8, 2020
  4. T1577707430565
    Cupcake Mar 10, 2020
    T1577707430565 , Mar 10, 2020 :
    if we received this update Google will officially release Android 11and 12 . and other premium companies will give update to the customers :p OnEplus lolliPop
  5. Vinodmandaar
    Gingerbread Mar 10, 2020
  6. pv+43
    pv+43 , Mar 10, 2020 :
    Hello, so my good old 3T will not get Oxygen 10? It is still going strong after 4 years except poor battery life even after swap. I have never seen a 4 years old phone perform this flawlessly. I'm sure it could handle the 10.
  7. R0hit bansal
    Cupcake Mar 11, 2020
  8. sandeepvarada
    Cupcake Mar 13, 2020
  9. Federico Prencipe
    Honeycomb Mar 13, 2020
    Federico Prencipe , Mar 13, 2020 :
    Maybe it's better this way, I had Android 10 from the very beginning but ut was full of problem, now it's a bit better but there are still a lot of problems.
    I'd rather have an older versione (Android 9) which works very well instead of having Andorid 10 very soon but having tons of issues.
  10. sandeepvarada
    sandeepvarada , via OnePlus 5T , Mar 13, 2020 :
    i accept but it's been 7 months since the official roll out of android 10, it's ample amount of time to fix and release. i am not expecting things to happen overnight.
  11. Federico Prencipe
    I don't accept it too, I'm using a 7 Pro, a much newer and expensive phone. It's a beast of a phone but it's poorly optimized so it doesn't work at its full potential
  12. sandeepvarada
    Yes, One plus\google should roll out the optimized one with fixtures.
  13. Federico Prencipe
    It's just OnePlus, not google, other phones work very well and had Andorid 10 pretty soon
    sandeepvarada likes this.
  14. Federico Prencipe
    Honeycomb Mar 14, 2020
    Federico Prencipe , Mar 14, 2020 :
    This would be very optimistic, they fixed a lot of bugs but there are still plenty. I have even a small issue in everything, wifi, battery drain, ringtones, camera, ram management, keyboard. Almost nothing works completely fine
    marcospcalixto likes this.
  15. marcospcalixto , via OnePlus 5T Midnight Black , Mar 14, 2020 :
    So it's better to continue with Android 9. I love my op for the battery and RAM management. If Android 10 comes with all this bugs I still really prefer the 9 one.
  16. Federico Prencipe
    Yes, a lot of people are doing this, the problem is with security pathces, if you stop upgrading you will be stuck with old security patches.
    In general Andorid 9 was much better than 10, I've been using it for 4/5 months, from May to Septeber 2019, from the moment I bought my 7 Pro to the moment they realased Andorid 10 and the differece was huge, specially at the beginning, now they reduced it somehow.
  17. marcospcalixto
    Cupcake Mar 14, 2020
    marcospcalixto , via OnePlus 5T , Mar 14, 2020 :
    The worst part is: if you want to do a down grade to the 9 you've make a root access. and OnePlus doesn't share the stock rom from what I heard.
  18. Federico Prencipe
    I don't know about the 5T but for the 7 and 7 Pro there are original rom available. The drawback is that if you want to install an older version you must format your phone, cancel everything and make a clean install. Same if you want to switch between beta and stable version.
    This is quite a big problem
  19. marcospcalixto
    good to heard that! I saw some information of rom stocks for OP is hard to find. probably they don't know where to looking for.
