860
OxygenOS based on Android 10 Incoming!
  1. Federico Prencipe
    Honeycomb Mar 14, 2020
    Federico Prencipe , Mar 14, 2020 :
    This would be very optimistic, they fixed a lot of bugs but there are still plenty. I have even a small issue in everything, wifi, battery drain, ringtones, camera, ram management, keyboard. Almost nothing works completely fine
    marcospcalixto likes this.
  2. marcospcalixto , via OnePlus 5T Midnight Black , Mar 14, 2020 :
    So it's better to continue with Android 9. I love my op for the battery and RAM management. If Android 10 comes with all this bugs I still really prefer the 9 one.
  3. Federico Prencipe
    Yes, a lot of people are doing this, the problem is with security pathces, if you stop upgrading you will be stuck with old security patches.
    In general Andorid 9 was much better than 10, I've been using it for 4/5 months, from May to Septeber 2019, from the moment I bought my 7 Pro to the moment they realased Andorid 10 and the differece was huge, specially at the beginning, now they reduced it somehow.
  4. marcospcalixto
    Cupcake Mar 14, 2020
    marcospcalixto , via OnePlus 5T , Mar 14, 2020 :
    The worst part is: if you want to do a down grade to the 9 you've make a root access. and OnePlus doesn't share the stock rom from what I heard.
  5. Federico Prencipe
    I don't know about the 5T but for the 7 and 7 Pro there are original rom available. The drawback is that if you want to install an older version you must format your phone, cancel everything and make a clean install. Same if you want to switch between beta and stable version.
    This is quite a big problem
  6. marcospcalixto
    good to heard that! I saw some information of rom stocks for OP is hard to find. probably they don't know where to looking for.
  7. Federico Prencipe
    Try to contact the support and ask them, there are a lot of links about rom for 6 and 7 series, I think you could find them also for 5 series.
    Or maybe write on the 5/5T official thread and ask if somebody knows.
  8. marcospcalixto
    Thank you for the tips pal! I'll do what you said, contact the support for rom stock. Thanks
  9. uddhavisgod
    Cupcake Mar 16, 2020
  10. sutanshu
    Gingerbread Mar 17, 2020
  11. F_Yathin_Raj_Amin_AgqE
    Cupcake Mar 22, 2020
  12. U1578771736341
    Cupcake Mar 26, 2020
  13. U1578771736341
    Cupcake Mar 28, 2020
    U1578771736341 , Mar 28, 2020 :
    Hello,
    After download the open beta 11 from your given link..i cant install this one because my oneplus 7 pro cant unzip this file ...what can do for this.
    I downloaded this zip file from google chrome and now this zip file is showing in download folder.
    What can i do for this next step...please help me on it.
    I am also unzip this file in my laptop and now paste it in android data folder.
    But in setting from local update there is not showing any update...
    Now i cant install it....
    Please admin help on this and what is my next step and what i do...
  14. Kytharsis
    Nougat Mar 28, 2020
    Kytharsis , Mar 28, 2020 :
    Um... where did you download it from?
  15. U1578771736341
    Cupcake Mar 29, 2020 at 7:21 AM
  16. Rajl khan
    Cupcake Mar 29, 2020 at 10:29 PM
  17. Kytharsis
    Nougat Mar 30, 2020 at 2:04 AM
    Kytharsis , Mar 30, 2020 at 2:04 AM :
    Work on your sentence structure first.
  18. Bikash sahoo
    Donut Mar 30, 2020 at 8:28 AM
  19. mrsolanki88
    Cupcake Mar 31, 2020 at 7:29 PM
    mrsolanki88 , via OnePlus 5 , Mar 31, 2020 at 7:29 PM :
    The amount of the OnePlus 5 was same as the latest One Plus 7 even you have settled your tag same as sumsung use to do sorry but no more one plus it better to get the Google flag ship for updates.
