695
OxygenOS Beta Program: Explained.
  1. RistoEe
    Honeycomb Feb 21, 2020
    RistoEe , Feb 21, 2020 :
    Just bought 7T pro McLaren and kinda shocking that latest security patch is from October 2019. That's four months old. Even my old 1+6 had newer security patch on it.
  2. DSTHaNK
    Donut Apr 26, 2020
    DSTHaNK , Apr 26, 2020 :
    I don't know but it's written here beta user get 2 updates every month but I'm not getting a single update when I created a thread some stupid person has closed that[e]1f621[/e][e]1f621[/e]
  3. Artemus.
    Nougat Apr 26, 2020
    Artemus. , Apr 26, 2020 :
    You have to be on the beta branch to get beta updates. And if you're on the 6/6T, the beta just ended.
  4. DSTHaNK
    Donut Apr 26, 2020
    I'm OnePlus 7 pro user and currently I'm using O2_beta 11 which came last month with March security updates so according to the update guide I should get beta 12.?
  5. Artemus.
    Nougat Apr 26, 2020
    otto2, Niklasg85 and DSTHaNK like this.
  6. DSTHaNK
    Donut Apr 26, 2020
  7. drummer79
    Gingerbread Apr 29, 2020
    drummer79 , via OnePlus 7 Pro , Apr 29, 2020 :
    Are you using the "Oxygen Updater" App? If not, download it from the play store and it will give you all the updates.
    DSTHaNK likes this.
  8. Darshan5015
    Froyo Apr 29, 2020
    Darshan5015 , via OnePlus 6 , Apr 29, 2020 :
    if you are 7pro user than give feed in 7&7pro forum not in this ..
    Artemus. likes this.
  9. DSTHaNK
    Donut Apr 29, 2020
    DSTHaNK , Apr 29, 2020 :
    So for your information from admin team a person given this link so I posted here, it's not my fault when I got correct link then I posted there. So before giving the suggestion you should also organise the phone model wise forum so we don't find difficulty to find that.
  10. DSTHaNK
    Donut Apr 29, 2020
    Thank you [e]1f60a[/e]
  11. dudo3
    Cupcake Jul 1, 2020
  12. N1593679741757
    Froyo Sep 13, 2020
  13. otto2
    Photography Expert Sep 13, 2020
    otto2 , Sep 13, 2020 :
    Never. Once on Beta you ll Stay on beta. Read opening post of the proper beta thread for more Informations.
  14. N1593679741757
    Froyo Sep 13, 2020
    N1593679741757 , via OnePlus 8 , Sep 13, 2020 :
    Thanks for the new update iam using one plus8 user and so far there is no such bug after the new update of android 11 in open beta 1
    But some how banking application is not working it's not allowing to login in to the app,I think that's the only issue I have after the update.
  15. raajesh6
    Cupcake Sep 17, 2020
  16. Harikrushn
    Eclair Sep 21, 2020
  17. Artemus.
    Nougat Sep 21, 2020
    Artemus. , Sep 21, 2020 :
    OP2? That phone's been discontinued for a looooooooooooooooong time.
  18. Harikrushn
    Eclair Sep 21, 2020
  19. R1599745880971
    Cupcake Nov 5, 2020
