134
OxygenOS features on OnePlus 7 series - How did we do?
  1. falconmoonpunch
    Froyo Jun 28, 2019
    falconmoonpunch , Jun 28, 2019 :
    Facebook messenger freezes when typing for me I have to lock and unlock to fix it all the time lol
  2. clarkgable
    Cupcake Jun 28, 2019
    clarkgable , Jun 28, 2019 :
    Oxygen OS is really good however when using Navigation Gestures, a way of swiping down the notification bar when you are somewhere other than the home page would be really welcome
    roryrudy likes this.
  3. Jimmyostrom
    Gingerbread Jun 28, 2019
    Jimmyostrom , Jun 28, 2019 :
    Can't OnePlus make an extra option in the future for OnePlus 7 Pro that makes the phone able to Use dex Och docking station to use the phone as a mini portable computer to connect to a screen and get a desktop.. Or are there some component missing to do that..?
  4. clarkgable
    I don't know if there's anything you can do software-wise about this, but it would also be very good if you can do something about the audio, both in terms of quality (most flagships are 32-bit 384hz audio these days) but also volume, especially on Bluetooth. It is not as loud as other phones on the market presently.
  5. P1560127459680
    P1560127459680 , Jun 28, 2019 :
    well turning on the fnatic mode switches on the data saver too and there's no way to disable it.
    #fnatic_mode #oneplus_7
  6. clarkgable
    V1558986198881 likes this.
  7. Ahsanjaved1986
    Froyo Jun 28, 2019
    Ahsanjaved1986 , Jun 28, 2019 :
    Always on display and screen being on always are two completely different things
  8. Prabal_titanium27
    Eclair Jun 28, 2019
  9. TomekDarda
    Froyo Jun 28, 2019
    TomekDarda , Jun 28, 2019 :
    Just allow it over other apps and you're good. The bottom gestures do not work, but you only need the side ones anyway, the bottom system ones are good and there anyway. It works flawlessly, just set it up, good luck.
  10. Ahsanjaved1986
    Froyo Jun 28, 2019
    I did allow it over other apps. Enabled all possible permissions but as soon as I lock the device and then unlock, it is disabled on its own :(
  11. JoshuaRamos28
  12. TomekDarda
    Froyo Jun 28, 2019
    I am sorry, I don't know how to help, lots of people use it and it works, there are also some tutorials on YouTube.
  13. Ahsanjaved1986
    Froyo Jun 28, 2019
    No worries man. Thanks for you help. Will look out for a solution.
    TomekDarda likes this.
  14. G_Chak_Koppula_IBzq
    G_Chak_Koppula_IBzq , Jun 28, 2019 :
    They already have this, there is a hidden app drawer, swipe up to access the app drawer then swipe right from the far left of your screen to access it, hope this helps!
  15. Rick_980B
    Eclair Jun 28, 2019
    Rick_980B , Jun 28, 2019 :
    I agree pocket mode is great I assume it means nothing can be pushed by accident while in your pocket
  16. IwantOneplus!
    Ice Cream Sandwich Jun 28, 2019
    IwantOneplus! , Jun 28, 2019 :
    shelf accessable left swipe from lockscreen. on unlock please replace shelf with Google now.
    single tap to wake. some sort of reachability feature because this phone is huge. unlock 90hz all times all apps.
    hold down on keyboard to move curser.
    swpie from left side to go back.
    improve swipe up for recent app and switch.. just isn't as smooth as apples.
    force system wide and apps in pure dark mode. ex. shelf and notification panel not black.
    need improvements with camera lol. thanks for listening
    fix Netflix not launching fix enable Dark mode in crome. I'm not able to dark mode there.
    .... fix Miss registration on fingerprint access. sometimes I'll have to press more than twice.
    PS. I already filled survey.
  17. fedevalladares
    Donut Jun 28, 2019
    fedevalladares , Jun 28, 2019 :
    Hi, it Is the first time I have a 1+, and I am really happy with it.
    Everything Is súper Easy and smooth.
    The only thing I am still measing from my previous devise is the dex mode.
    Whould be great if you could give us something similar.
    Cheers!
  18. Rick_980B
    Eclair Jun 28, 2019
    I know what is is I had it one my Note 8 but didn't use it. thanks anyway I forgot
    fedevalladares
    Cheers!​
    what is dex mode
  19. fedevalladares
    Donut Jun 28, 2019
    It Is a feature that Samsung and huawei have, and turne your phone in a computer.
    With a cable or simply by Bluetooth you conect the phone with a screen, and allows you to see and manage your data like a desktop
  20. SuperMan92
