137
OxygenOS features on OnePlus 7 series - How did we do?
  1. O1566115576455
    Cupcake Aug 18, 2019
  2. O1566115576455
    O1566115576455 , Aug 18, 2019 :
    the camera needs improvement in one plus 7 as the front and back camera makes the skin tone yellowish. it is not natural and it makes the skin more yellowish.please do some omprovememt
    0177382345 likes this.
  3. epic_seo_see
  4. KiranKumarN
    KiranKumarN , Aug 18, 2019 :
    need adaptive brightness optimisation..not works fast and according to environment light
  5. L1564747442019
    Donut Aug 18, 2019
  6. NOOSHITH_satish
    Eclair Aug 18, 2019
  7. VinodGOP7
    Froyo Aug 18, 2019
    VinodGOP7 , Aug 18, 2019 :
    Please check under Settings->Sound & vibration->Do Not Disturb->Turn on automatically" if any automatic "Do not disturb" automatic mode/rule is enabled.
    Thanks,
    Vinod
  8. O1566105640619
    O1566105640619 , Aug 18, 2019 :
    thanks a lot
    I checked and found that do not disturb is off.
    I think the slider button has problems.
  9. VinodGOP7
    Froyo Aug 18, 2019
    Oh ok. Then, you can get it checked at the OnePlus service center.
    Thanks,
    Vinod
    KiranKumarN likes this.
  10. kenshin7
    kenshin7 , Aug 18, 2019 :
    please add gestures swipe from left or right for back action. its better than swipe up from left or right of the bottom of the screen.
    W1541536202739 likes this.
  11. theodroid
    theodroid , Aug 18, 2019 :
    Features which I would like to see:
    1) Pocket mode
    2) Emulate an LED notification light by using a colored dot on top of the screen
    3) Always on display
    4) Google News feed instead of OnePlus Shelf
    and better translations.. French translation is pretty poor.
    For example on the shutdown menu it's written "verrouillé" instead of "verrouiller". In the vibration intensity selection menu, it's written "lumineux" instead of "léger", etc...
    CMX35 and C1564504611861 like this.
  12. H1562156971231
    CMX35 likes this.
  13. T1566150037037
    T1566150037037 , Aug 18, 2019 :
    There's already a pocket mode, I can see it right now on my OP 5t. You can find it by going to the settings and typing "pocket mode" on the search bar. Thank me later.
  14. Waris512
    Waris512 , Aug 18, 2019 :
    The 48 megapixel feature should be available to use with the auto camera.In images there needs to be a substantial improvement to detail and clarity in the darkest parts in the images taken form the cameras as they appear blurry and washed out.
  15. Waris512
    there is a lack in f datail and clarity in the image. it would help if there was a option to use 48 mp in auto mode with the added flaxability of of being able to use her and the three lenses. also I have noticed that the darkest parts in images I have taken lack detail and clarity and needs to be improved in a future update.
  16. Waris512
    when is the update oxygen 9.5.12 going to be rolling out and will it improve the camera performance taking in into account the feedback that you have received.
  17. A1565724007264
    A1565724007264 , Aug 18, 2019 :
    not in OnePlus 7 man....in op5t it has proximity sensor.,but in op7 due to size of notch..proximity is absent and works of proximity are done by other sensors like gyro etc..
  18. bharathbaiju
  19. T1566150037037
    It's in spanish, but if you translate it (don't take my word for it), you'll see it's the pocket mode. Maybe it's because on a 5t the story is a different one, I don't trully know. That would be interesting, tho.
  20. Jessy142
