167
OxygenOS features on OnePlus 7 series - How did we do?
  1. M1567258502681
    Cupcake Sep 20, 2019
  2. VictorBoqui
    VictorBoqui , Sep 20, 2019 :
    I would like to run 2 apps at the same time (as Xiaomi and Samsung). Today I can split the screen and see two apps, but they don't run simultaneously.
  3. Meister1977
    Gingerbread Sep 20, 2019
    Meister1977 , Sep 20, 2019 :
    It would be really nice if OP could fallback between the two sims for internet. So if the no connection on the prefered network, phone starts to use the other, and when the net comes back, it starts to use the preferred sim again.
  4. Aman800
    Aman800 , Sep 20, 2019 :
    Good, very good, but still unfortunately I have to report a bug with my Bluetooth connection, I own a oneplus 7 and it's frequently disconnecting from my Bluetooth earphones and car Bluetooth, also some time it gets connected to a ghost Bluetooth connection, with no name, when I try to increase volume then only my phone shows it's connected to Bluetooth, but Bluetooth isn't even on.. please try to fix it in next update.
    For a phone without 3.5mm jack it's a real problem..
  5. UI561960973800
    Cupcake Sep 21, 2019
    Aman800 likes this.
  6. M1567258502681
    M1567258502681 , Sep 21, 2019 :
    I think did wrong thing by installing beta version so many issues in this
    mobile data switch is not working even after switching its trying with different slot Sim
    and new gestures are not good
    camera having problem
    screen auto brightness having problem
  7. R1545021630140
    R1545021630140 , Sep 21, 2019 :
    I have to say, out of all of the features I'd like to see tweaked, it'd have to be the front camera retraction being faster, and the double tap to wake being more responsive. There are times the double tap activates in the process of putting my phone in my pocket, and others where I can deliberately double tap with no response.
  8. Trissandom
    Cupcake Sep 23, 2019
    Trissandom , Sep 23, 2019 :
    Proximity sensor is fail, when I play to records on whatsapp or telegram, screen gona shut down and active ear speaker, but I dont do anything, it is on the desk.
  9. awsumatt
    awsumatt , Sep 23, 2019 :
    Well they don't have space for a proximity sensor so.....
  10. aburmrm
    Eclair Sep 23, 2019
  11. clips
    Gingerbread Sep 24, 2019
    clips , Sep 24, 2019 :
    aren't the sensors under the display? I don't think it would work that well.
  12. Csevege
    Cupcake Sep 24, 2019
    Csevege , Sep 24, 2019 :
    I don't know if anyone said it already or not but wish I could just slide my finger on the side of the screen to adjust brightness and volume. Don't like auto brightness, is too dimm for my eyes, have to adjust brightness a lot.
  13. G_Sanjeet_Sharma_nyzQ
  14. O1566793978585
    O1566793978585 , Sep 24, 2019 :
    Здравствуйте! Почему то с перебоями работает автоповорот экрана.
  15. Shafiq Rahman.T.H.
    Shafiq Rahman.T.H. , Sep 24, 2019 :
    guys...
    I am using the one plus 7 and I am having trouble finding a screen protector that covers the entire display. The edge to edge ones normally come with a border which tends to hide a bit of the display and the normal ones usually don't cover the entire display which leads to some edge bleed. Can anyone recommend a screen protector that they are using and doesn't have these issues?
  16. W1563049984941
  17. Chhunhour_Kh
    Froyo Sep 24, 2019
  18. N1567879570809
  19. TommyHammy
    TommyHammy , Sep 24, 2019 :
    This has been said quite a few times before but the auto brightness is too agressive. It dims too much. Even when I raise the auto level back to half way it will drop all the way back down within 5 seconds. I know it's auto and it will dim when it senses it, but there's no need for it to go to the dimmest setting in a living room with a lamp next to me.
  20. Gite Baladou
