168
OxygenOS features on OnePlus 7 series - How did we do?
  1. Venkatesh_thota
    Froyo Oct 18, 2019
    Venkatesh_thota , Oct 18, 2019 :
    same with me bro...did u find any solution to it?
  2. Ashwarth
    Cupcake Oct 18, 2019
    Ashwarth , via OnePlus 7 , Oct 18, 2019 :
    first I loved oxygen, tqs for fluid and butter smooth andoid os. and also fast quick updates.
    1. first I noticed is 2x goom camera.i think so..it's waste, why because not working properly every thing blur images. i think so please update on next update.
    2.fast, fluid and butter smooth experience ui fine.but it is normal and basic UI only not get feeling like rich look UI
    please focused on rich look UI like IOS
  3. B1567244785828
  4. D1532368388424
    D1532368388424 , Oct 18, 2019 :
    my phone gets hang while using some apps such as gallery. I'm unable to send pictures from there. The app keeps stopping after I updated my phone to the latest version. Pls help fixing the bugs. Also the settings kind of keeps on changing such as in Netflix I can't use the status bar while some video is going on but I could do that before. I have no idea what is happening to my phone.
  5. vincentbx715
    vincentbx715 , Oct 18, 2019 :
    You did bad! Bring back all thegood things from android 9!
    Please dont make me regret choosing oneplus!
  6. ssrana3890
  7. vincentbx715
    Cupcake Oct 19, 2019
    vincentbx715 , Oct 19, 2019 :
    Please note that the GPU took a hit in thw 10.0.1 update for oneplus 7.
    All tests in antutu now stutter. Previously the 3d tests were all smooth sailing 60fps!!
  8. Malvika.11
    Malvika.11 , via OnePlus 7 , Oct 19, 2019 :
    pocket mode is very much required...
    while in pocket screen always gets disabled, have to type password Everytime to unlock phone
  9. KotamSun
    Donut Oct 19, 2019
    KotamSun , via OnePlus 7 , Oct 19, 2019 :
    Button & Gestures setting is not available on the other user roles, instead it is defaulted to 'Fixed Navigation Bar'.
    This was working fine for all the other roles in android pie.
  10. chwads786
    chwads786 , Oct 19, 2019 :
    how about release android 10 and kernel sources for 5g version instead.of.ignoring our devices . so poor
  11. Amr Abdallah
  12. I1564848344768
    Cupcake Oct 20, 2019
  13. parthj13
    Donut Oct 20, 2019
    parthj13 , via OnePlus 7 , Oct 20, 2019 :
    Recently I got Oxygen OS 10 update on my Oneplus 7 device.
    i have noticed that few things are removed from the latest version if we compare it with 9.5.xxxx version.
    1. killing any application , stopped all the services of that particular application. There was an option in settings in previous version but now in Oxy 10 i don't see that option.
    2. Themes part is not working properly. Random issues are visible there.
    3. Battery drains faster with oxygen 10 but previously battery went well through out the day!!
    please try to fix those things and please get us back the option where all services gets disconnected once one kills the application.
    mahekparmar likes this.
  14. Andy lone
    Honeycomb Oct 20, 2019
    Andy lone , Oct 20, 2019 :
    bring back the battery saver after charging at the moment after updating need to do manually every time after charging
  15. P1570423393337
    P1570423393337 , via OnePlus 7 , Oct 20, 2019 :
    One plus 7 feedback.
    At times, whatsApp audio calls doesn't work at times, the regular phone voice doesn't work, especially when the headphone is plugged... then I have to reboot to get it proper...
    A lag is detected (very slow or getting stuck) multiple times during a day.
    Anyone facing similar issues?
  16. I1564848344768
    I1564848344768 , via OnePlus 7 Pro , Oct 20, 2019 :
    any body here,
  17. P1570423393337
    Will anybody address - OnePlus 7 issue...
    Why I have to reboot my phone every day for smooth functioning??? Whenever the below mentioned issues occur, a reboot helps. But why should I reboot daily?????
    1. At times, even if the ring volume is high, it doesn't ring.
    2. If we try to download videos from WhatsApp, it have a serious lag, it will not stream smoothly.
    3. Apps get too slow atleast once daily and phone gets hang
    4. Many a times, WhatsApp calls doesn't ring, will not hear audio in both audio n video calls.
  18. Georgeoneplus7pro
    Jelly Bean Oct 20, 2019
    Georgeoneplus7pro , Oct 20, 2019 :
    Optimize GPS on OnePlus 7Pro. Sometimes I am located on the Google Map more than 50 meters from where I am. The device is equipped with dual-band GPS and you just need to adjust the software for good accuracy.
  19. b0gl
    Cupcake Oct 21, 2019
    b0gl , Oct 21, 2019 :
    The only thing I am missing is the ability to pulse the notification light every x seconds when I have recieved a notification. The pulse beat app does this but it seems to be broken with the latest update.
  20. CatPandaFish
    Froyo Oct 21, 2019
    mahekparmar, CMX35 and gonzalobici like this.
