151
OxygenOS features on OnePlus 7 series - How did we do?
  1. Z1567245281702
    Cupcake Oct 29, 2019
  2. J1572088642201
    J1572088642201 , Oct 29, 2019 :
    Thanks to oneplus team to have a survey for improvement for the OS.
    I am a oneplus 7 user.
    Here is my suggestion:
    1. The adaptive brightness still need to improve more as it cannot sense the correct brightness in real situation.
    2. Introducing of the "pocket mode".
    3. Improve the battery saver system and improve the battery optimization as the battery drain is very fast.
    4. Improving the "ambient display" as it will not work when the screen is lock for a long time.
    5. Improve the vibration system. It still not stable sometimes as the noticed come but not vibrate at all and i need to reboot my phone.
    6. Introducing the own build in apps as gallery (which already have), music and video player. It is important as i prefer use the own build in player than using other third party apps such as Google apps.
    7. Introducing the "floating ball". It is more easier to lock the screen without press the lock button and other feathers as well.
    8. Introducing the RAM cleaner and the phone manager.
    That all for my opinion, hope that oneplus team can consider my suggestion. Thank you.
  3. _shubham321
    Donut Oct 29, 2019
    Huthaifa_Bz likes this.
  4. K1571139238320
    Donut Oct 29, 2019
    K1571139238320 , Oct 29, 2019 :
    1. fingerprint scanner working slow
    2. lots of hang while watching YouTube, Netflix or normal use etc
    3. sometimes always on display doesn't work when tap on the screen to see date and time.
    4. please update battery performance.
    5. doesn't feel like if you are using SD855. need to be fast
    L1562430375226 and Amr Abdallah like this.
  5. F_Abhi_Jariwala_qnwo , via OnePlus 7 Pro , Oct 29, 2019 :
    It would be great if you could add a feature for detecting that the incoming message contains OTP and directly show the option "Copy OTP" from the notification itself.
    It would be really helpful in day to day life.
    K1571139238320 likes this.
  6. A1570848477642
    A1570848477642 , Oct 29, 2019 :
    one more add feature one plus music player
    J1572088642201 likes this.
  7. Atiq1989
    Froyo Oct 29, 2019
    Atiq1989 , via OnePlus 7 Pro , Oct 29, 2019 :
    After updating Android 10 i Can't find "Recent App management" (Normal Clear or Deep Clear) option in system setting.
    can you please tell me where it is or removed.....?
    we strongly want this feature.......
  8. indiana99
    Cupcake Oct 30, 2019
  9. D1567987190888
    Cupcake Oct 31, 2019
    D1567987190888 , Oct 31, 2019 :
    The new keyboard layout is arguably worse after the latest update. Keep hitting the home/back button.
    Also is it possible to view previous steps done with the step counter?
  10. Camelon
    Eclair Oct 31, 2019
  11. D1567987190888 likes this.
  12. RohanShelar333 , via OnePlus 7 Pro , Oct 31, 2019 :
    BETA version could be an issue, create a thread for the same and help One plus with the screen recording for the same
  13. zsbotond
    Eclair Oct 31, 2019
    zsbotond , via OnePlus 7 , Oct 31, 2019 :
    It would be nice if we could make presets in the customizations menu, which would be saved combinations of customization options which could be easily toggleable. Also, it would be the best if there could be an automatic switcher between light and dark tones, for example at sunset/sunrise or in low-light environments. Thank you.
    DK23kumar and Adi_2019 like this.
  14. SanthoshPulliman
    SanthoshPulliman , via OnePlus 7 , Oct 31, 2019 :
    Vibrate is not at all fixed in Android 10 beta4
  15. Adi_2019 , via OnePlus 7 Mirror Blue , Oct 31, 2019 :
    1. I am on stable channel.
    2. Since it happens during typing on gboard, I will try to generate the issue.
    3. It may not be the case but interestingly, I noticed that Mi A2 phone used to freeze during typing sometimes. OnePlus 7 does not freeze but switches to home. Maybe gboard is the cause. It's unlikely but those who text a lot can help in testing it.
  16. gonzalobici
    Donut Oct 31, 2019
  17. E1562836393740
  18. FranMaya
    FranMaya , Oct 31, 2019 :
    In my opinion top 2 features to implement would be
    1) One handed mode using some type of gesture
    2)Wifi sharing with hotspot
    On galaxy(my phone prior to this device) I was able to enable my wifi hotspot and connect other devices to it, but I was able to connect to a wifi point from my phone and essentially use the internet from the wifi point to provide the other devices connected to my hotspot internet without using mobile data
  19. Wahibmichael
    Cupcake Nov 1, 2019
    D1559279532306 likes this.
