71
OxygenOS installer
  1. dj.barnwal
    Cupcake Apr 4, 2015
  2. deimos11
    KitKat Apr 4, 2015
    deimos11 , Apr 4, 2015 :
    yes after unlocking back to normal interface and when you click install oxygen os it will do its thing it will remove everything except for internal storrage
  3. rahulprakash
    Eclair Apr 4, 2015
  4. deimos11
    KitKat Apr 4, 2015
    yes it will except internal storrage
  5. dj.barnwal
    Cupcake Apr 4, 2015
    dj.barnwal , Apr 4, 2015 :
    How can I recover them? Sorry I am a noob in these things :(
  6. Schlumi
    Ice Cream Sandwich Apr 4, 2015
  7. deimos11
    KitKat Apr 4, 2015
    uhm.. you can backup your contacts to google cload etc and your apps you can download them from the store you need to update anyway so but now then later
  8. Alexbobaz
    Eclair Apr 4, 2015
  9. deimos11
    KitKat Apr 4, 2015
    Schlumi likes this.
  10. deimos11
    KitKat Apr 4, 2015
    go to settings, about phone, tab build number 7 times, go to developer settings, enable android debugging/usb debbuging/adb
  11. Philippe75
  12. deimos11
    KitKat Apr 4, 2015
    its even on the first page lol
  13. Schlumi
  14. deimos11
    KitKat Apr 4, 2015
    yes you only need to enable adb and have unlocked your bootloader
    then go back to normal interface and click isntall oxygen os it does everything fully automaticly
    Schlumi likes this.
  15. rai007
    Gingerbread Apr 4, 2015
    rai007 , Apr 4, 2015 :
    Great work. Seems the best and easy method to install OxygenOS till now.
    Pls provide "back to stock rom" tool also. Do u have any links where i found easy and simple method to flash my OPO back to stock rom cm11-XNPH05Q without rooting.
  16. laurenttoulotte
    Froyo Apr 4, 2015
  17. jcsaints
    Cupcake Apr 4, 2015
  18. rrazdan
    Donut Apr 4, 2015
    rrazdan , Apr 4, 2015 :
    this is exactly what I was looking for ...plz for newbies like us can u post a detailed step by step guide for OPOs which have not tweaked software wise - no unlocked bootloaders etc etc
  19. iridtur
    Cupcake Apr 4, 2015
  20. Alexbobaz
    Eclair Apr 4, 2015
    Alexbobaz , Apr 4, 2015 :
    i know i'm a total noob in this but, could you publish a little guide to use your software both for flashing oxygen and cm11s (if i want to go back)?
