639
OxygenOS is here [Installation Guide]
  1. Bradon H
    Honeycomb Apr 3, 2015
    Bradon H , Apr 3, 2015 :
    Friends,
    Many of you around the world are off work today for a long weekend. We hope to make your vacation even better, because OxygenOS is finally here!
    We know you’ve been patient, and we’re excited to announce that starting right now, you can download and flash OxygenOS right to your OnePlus One.
    Be sure to check out oneplus.net/oxygenos for more information.
    The OnePlus Forums are where everything started, and we couldn’t have gotten this far without you. Your suggestions and feedback have strongly influenced the direction of Oxygen, and we consider all of you a part of the team. This ROM was built just for you, and we can’t wait to hear what you think. We’ve made a feedback app available for download on OxygenOS, and we hope you’ll use it. Let’s make Oxygen even better, together.
    Installation Instructions:
    Download OxygenOS HERE
    Download Feedback App HERE
    Note: You’ll need to enable installations from unknown sources (settings > security) in order to install the feedback app on OxygenOS.
    Please make sure all your data and files are backed up before commencing. Flashing OxygenOS onto CM does require a system wipe, so you will lose all of your data. We are actively working on an easier, more automated solution soon to be available, but for now the build must be flashed manually. Please note, OxygenOS only runs on a OnePlus One device, do not attempt to flash this on any other device.
    Please proceed only if you are confident in your abilities to flash a custom ROM. This guide exists to help you flash OxygenOS, but things can still go wrong if not followed correctly. While rooting and flashing will not void your OnePlus warranty, any damage caused by improper flashing is not covered under warranty.
    The following instructions assume you have Fastboot and ADB installed.
    Step 1
    You first need to flash a recovery onto your device. We recommend using TWRP. Please download the recovery image to your computer. You can follow their instructions to flash recovery, or you can reference these steps:
    • Boot into fastboot mode. You can do this on your OnePlus One by holding down the power button and the volume up button. When you see the fastboot logo, connect your device to your computer.
    FOR WINDOWS USERS:
    • In your terminal window, find the folder where you put the recovery image and run the following commands:
    fastboot oem unlock (You can skip this step if your phone’s bootloader is already unlocked).
    fastboot flash recovery <recovery.img>. Image file should be the TWRP recovery image.
    fastboot reboot
    FOR MAC USERS:
    ./fastboot oem unlock (You can skip this step if your phone’s bootloader is already unlocked).
    ./fastboot flash recovery <recovery.img>. Image file should be the TWRP recovery image.
    ./fastboot reboot
    You should now have the recovery installed.
    Step 2
    Unzip oxygenos_1.0.0.zip. In there, you will see a oxygenos_1.0.0.flashable.zip file. Copy oxygenos_1.0.0.flashable.zip to your phone. On a Mac, you can use Android File Transfer.
    Step 3
    Boot into recovery. You can do this on your OnePlus One by holding down both the volume down key and the power button.
    Step 4
    Once you are in the recovery interface, the first thing you want to do is a factory reset. Again, you will lose all your data so please make sure you have backed up everything before doing this.
    Step 5
    After the wipe, go to install and find oxygenos_1.0.0.flashable.zip. Confirm flash. This will flash OxygenOS onto your device.
    Step 6
    After the flash succeeds, you can reboot the device, which will take you to the new OxygenOS. Enjoy!
    If you find yourself wanting to rollback to CM, Make sure you have TWRP or CM recovery on the device. Another factory reset is needed before flashing unfortunately so make sure you backup all of your data.
    Never Settle.
    List of known issues:
    • When printing images, printer service may stop
    • Cannot hang up a call using headphone controls (intermittent)
    • OTG can only recognize FAT32 file system
    • During system update, display of wifi/data notification may be incorrect
    • During system update, display of version number may be incorrect
    • Files sometimes crash when uploading files to the cloud
    • Files may crash when renaming image files
    • Files does not support multi-select deletes
  2. Formsma
    KitKat Apr 4, 2015
  3. mmrbest
    Jelly Bean Apr 4, 2015
    mdup17, mr chinese, xpersian and 19 others like this.
  4. Rimmo96
    Ice Cream Sandwich Apr 4, 2015
    mdup17, erandok, xpersian and 6 others like this.
  5. Mjo
    Marshmallow Apr 4, 2015
    Mjo , Apr 4, 2015 :
    Thank you :) :)
    Edit: Installed. :) Checking it out :3
    Charging it at the moment. Smooth. Simple. Ordinary Android L experience. :) Issues found are the same as the Issues thread. But it's the first run..So who knows what the next update will bring. :)
    Update: Batt is not that great. But will observe some more :) Screenshot below.
    Update: Well back to CM11s for me. Maybe on the next OxygenOS release,I'll flash again :)
  6. jkb114
    Lollipop Apr 4, 2015
    jkb114 , Apr 4, 2015 :
    Wow. Well done guys. For a first attempt at a ROM I'm impressed. Guys there may be some bugs but that's what's the best thing about this community. We'll work together to find them and fix them to build a ROM worthy of the one plus name.
    sudersanva, mdup17, cdisxm and 5 others like this.
  7. sudeeptakoor1
    Honeycomb Apr 4, 2015
    Fstop, mdup17, dohalad and 4 others like this.
  8. ninjasumit
    ninjasumit , Apr 4, 2015 :
    Finally. Thanks!
    Edit: Flashed successfully. This is the fastest lollipop ROM as of now but it feels kind of incomplete. No double tap to sleep and some minor glitches here and there. Its better to stick to Exodus for now. Waiting for CM12S now, expect it to be a lot better.
  9. #gayed98#
    Gingerbread Apr 4, 2015
    mdup17, mantas001, pleymor and 2 others like this.
  10. menacho.eulogio
  11. xythiii
    p-d, mdup17, mantas001 and 3 others like this.
  12. ExcludedDroid
    Donut Apr 4, 2015
    mdup17, mantas001 and Ahmed Adel like this.
  13. holzfeli
    holzfeli , Apr 4, 2015 :
    I'm a bit disappointed about OxygenOS, because there are no special features.
    Now, back to stock ;)
    mdup17, immanuela, mantas001 and 10 others like this.
  14. __saurav
    Froyo Apr 4, 2015
  15. SACHIN DABAS
  16. trumpet78
  17. Akki4Trespasser
    ZobairQ and pytqon like this.
  18. GreenFirework
  19. hassan95
    Froyo Apr 4, 2015
    sujayu711 likes this.
  20. anupsnair
    Cupcake Apr 4, 2015
