638
OxygenOS is here [Installation Guide]
  1. awadi888
    Gingerbread Apr 4, 2015
    awadi888 , Apr 4, 2015 :
    try reading this site on how to root your phone. This will help you install the recovery a.k.a TWRP that you need in order to flash Oxygen
  2. sjstays
    Froyo Apr 4, 2015
  3. sagarbalsari
    Ice Cream Sandwich Apr 4, 2015
    sagarbalsari , Apr 4, 2015 :
    Dude you cannot get ota for oxygen while you are using cyanogenmod.
  4. Appleboom
    Donut Apr 4, 2015
  5. semper80
    semper80 , Apr 4, 2015 :
    For all cupcake: http://www.wugfresh.com/brt/ - is a toolkit for root your phone, unlock bootloader and install a custom recovery
  6. Tomas Trastromer
    Cupcake Apr 4, 2015
  7. Tomas Trastromer
    Cupcake Apr 4, 2015
  8. jayvin2013
    Eclair Apr 4, 2015
    jayvin2013 , Apr 4, 2015 :
    Success. But good god does it take forever. Then again this file is almost a whole GB. (0_0)
  9. semper80
    You can install the new OS after you complete all the steps in the link
  10. anindya.biswas
    Cupcake Apr 4, 2015
    anindya.biswas , Apr 4, 2015 :
    Nice first release hope to see more features in future updates. Will we get ota updates if I upgraded to oxygen.
    In future release I would like an option to remove useless google apps. Also Swipekey if possible.
  11. chadbartley
    Froyo Apr 4, 2015
    chadbartley , Apr 4, 2015 :
    Any one help me here. I am slightly computer literate. This flashing should not be an issue but damn is it hard to find instructions that actually tell you how to do this ""The following instructions assume you have Fastboot and ADB installed."" I have followed instruction to these links and the .batch_profile is nowhere to be found. Really want to try out oxygen. Using a mac. Any help from a master would be more than appreciated.
    justZique likes this.
  12. flameonfzn
  13. p.pavljasevic
    Donut Apr 4, 2015
    p.pavljasevic , Apr 4, 2015 :
    Yea you will het OTAs
  14. semper80
    After you have unlocked, after you installed a recovery, you to put Oxygen in SD card > go to recovery(TWRP)> wipe factory reset> install> search OS in your SD> install. Before installation would be good to do a backup system
  15. jmorris20012001
    jmorris20012001 , Apr 4, 2015 :
    Try WUG's Bacon Root toolkit
  16. Sub-Negro
    Honeycomb Apr 4, 2015
  17. avocrack
    Cupcake Apr 4, 2015
  18. benjaribeiro
    Donut Apr 4, 2015
    benjaribeiro , Apr 4, 2015 :
    Yes we will
  19. jayvin2013
    Eclair Apr 4, 2015
    I am going to assume that you haven't done anything to your phone in order to prepare for downloading the rom, so I'll walk you through. First, you have to select "Full Driver Instillation Guide...". This is going to allow your phone to get the adb drivers crucial for being able to even use the program. Second, select "Unlock". As stated, it will delete all of your phones content, so it is recommended that you make a back up of that. Including storage, i.e. files, pictures and videos, just in case. Third, select "Root" and check mark "Custom Recovery". This will root your device and install the custom recovery of your choice. TWRP is highly recommended. Finally, download the OxygenOS file and unzip it to get the actual rom file. Transfer that file to your phone and then go to recovery mode. You do that by pressing volume down and the power button. Now what I recommend is you make a backup of your current rom. Just go to backup and make one. Afterwards, go to wipe and advance wipe and select everything EXCEPT "Internal Storage" and "Usb-otg". Wipe it. Finally, go to install, look for your rom file and flash it to your phone. This process will take a while so be patient. Once it has finished, reboot your phone.
  20. jayvin2013
    Eclair Apr 4, 2015
    The same goes to anyone else that needs assistance.
