639
OxygenOS is here [Installation Guide]
  1. bold1989
    Donut Apr 5, 2015
  2. OPToxic
    Honeycomb Apr 5, 2015
    OPToxic , Apr 5, 2015 :
    I think your Broadband must be a joke. downloaded in a few minutes here on a 40mbs connection.
    cwalt2166 and jorgeribeiro199810 like this.
  3. DeltaSky
    Ice Cream Sandwich Apr 5, 2015
    DeltaSky , Apr 5, 2015 :
    Give it a try, it's worth, super smooth and fast. Let's see what cm comes up with.
    jorgeribeiro199810 and nickizm like this.
  4. dattatray279
    Gingerbread Apr 5, 2015
    dattatray279 , Apr 5, 2015 :
    It was not a big issue. You just had to disable a feature of accidental wake up from settings.
  5. Deactivated User
    Apr 5, 2015
  6. npatula
    npatula , Apr 5, 2015 :
    Does this need to install over cm11 or can I install it over cm12 nightly?
  7. xiaocookie
    Cupcake Apr 5, 2015
  8. Psychetron
    Cupcake Apr 5, 2015
    Psychetron , Apr 5, 2015 :
    I used this rooted OTA based ROM from here: https://forums.oneplus.net/threads/rom-nov-7-stock-rooted-xnph44s.173329/
    Unfortunately, since this is a downgrade you will lose your current settings/data. I think there's some instructions floating around that has a flashable ZIP that can help, but I think it's still risky (when downgrading). You will also need to have TWRP or similar bootmanager
    I did a factory Wipe > Install Zip file > wipe dalvik/cache , pretty much it. I mostly hated the battery drain that seems to be happening with the 05Q. I also hate MaxxAudio (it only supports Play and a few other apps). Viper4Android is hard to beat.
    Lobogris likes this.
  9. nickizm
    nickizm , Apr 5, 2015 :
    I will do in the morning.. downloaded the file which seem overly large for a rom.. Hearing a lot of issues with the battery tho
    gaga64 likes this.
  10. Eko_cahyono
    Eclair Apr 5, 2015
    Eko_cahyono , Apr 5, 2015 :
    I see you have flashed the wrong zip file...you must extract the zip first...there will be a flashable zip file in it...and flash that
  11. biswas1986
    biswas1986 , Apr 5, 2015 :
    Serious excited to have Oxygen Os up and running. Just had it installed, still going through now.
    But as I go through, I find myself to have been over excited about the release.
    The build is definitely light, but seems it has some major lack in features.
    For a one liner - It's pure stock!!! Except a few tickles here n there.
    Guess I over shoot my estimation. However, the build is sleek and robust... No issues whatsoever in the initial hour of use.... But seriously lacking features :(.
    I am still vouching to Never Settle.
    Edit: You can flash maxxaudio at least though ;-)
  12. onepluskitty
    Froyo Apr 5, 2015
    onepluskitty , Apr 5, 2015 :
    Same problem here. Have you found a fix yet?
  13. SpicyMan
    Eclair Apr 5, 2015
    SpicyMan , Apr 5, 2015 :
    After a day with the Oxygen OS, I can say I'm happy..
    Minor issues I discovered - not fully in Hebrew as the CM is.. The clock app doesn't work at all- I downloaded a different one instead..
    For some reason it doesn't show the weather.. And I haven't succeed in installing it as a second ROM through Multirom..
    But I staying with it in the min while..
    IT LOOKS ELEGANT!
  14. dhames
  15. existant60
    Cupcake Apr 5, 2015
    existant60 , Apr 5, 2015 :
    Can someone let me know of the hotspot tethering will give me unlimited hotspot and doesn't show up as being used as cm12 does?
  16. shreyasrock2
    Donut Apr 5, 2015
    shreyasrock2 , Apr 5, 2015 :
    Guys ..have anyone tried downgrading to 44s from oxygenos? Is it ohk to flash 44s through adb?
  17. Jalamillo67
    Cupcake Apr 5, 2015
    Jalamillo67 , Apr 5, 2015 :
    Did any of you extract and flash the correct zip file?
  18. GTI
    Donut Apr 5, 2015
    GTI , Apr 5, 2015 :
    Step 2
    Unzip oxygenos_1.0.0.zip. In there, you will see a oxygenos_1.0.0.flashable.zip file. Copy oxygenos_1.0.0.flashable.zip to your phone.
  19. M4ENY
    KitKat Apr 5, 2015
    M4ENY , Apr 5, 2015 :
    Do you prefer the Oxygen over the CM?
    Mjo likes this.
  20. boggogo
    boggogo , Apr 5, 2015 :
    Can we have some news on CM12S, please ? :)
