639
OxygenOS is here [Installation Guide]
  1. radhalokesh
    Gingerbread Apr 5, 2015
    radhalokesh , Apr 5, 2015 :
    better wait for cm12
  2. marcyeo
    Ice Cream Sandwich Apr 5, 2015
    marcyeo , Apr 5, 2015 :
    it would be great if u guys can include tap to sleep function...also i noticed that when play video using mx player it is a bit lag compare to cm11s..media volume also softer than cm11s
    pratheep_s likes this.
  3. wintermi
    Eclair Apr 5, 2015
    wintermi , Apr 5, 2015 :
    Just installed OxygenOS via the Mac myself. Super easy. Highly recommend you install Homebrew (http://brew.sh/). Once installed you can install the Android Platform Tools with a single command (
    brew install android-platform-tools). This will give you both adb and fastboot without any messing around. Simple.
  4. mattfohs2006
    Cupcake Apr 5, 2015
    mattfohs2006 , Apr 5, 2015 :
    Did you extract the zip file before flashing?
  5. pratheep_s
    Froyo Apr 5, 2015
    pratheep_s , Apr 5, 2015 :
    Missing double tap to sleep !! For lag try s/w decoding.
  6. cafefe
    Froyo Apr 5, 2015
    cafefe , Apr 5, 2015 :
    Do not understand why complain so much , if at the end we got what we wanted . Lolipop !!!
    Putting all cyanogenmod options is to make a copy.
    The Oxygen OS developers team did a great job !
  7. Fuad_Hossain
    Honeycomb Apr 5, 2015
    Fuad_Hossain , Apr 5, 2015 :
    oh thank you the guide is hard to follow did u flash oxygen os?
    apxrdm likes this.
  8. krishnavfx
    Froyo Apr 5, 2015
    krishnavfx , Apr 5, 2015 :
    Woo hoo thanks for the most awaited update and appreciate the hard work of oxygen team and keep rocking guys .
    NEVER SETTLE.
    Walkin_mn likes this.
  9. carvados
    carvados , Apr 5, 2015 :
    Not that delicious my friend. Be patient and wait for CM12s. Don't get yourself into trouble by trying to flash this ROM.
    RizBrat likes this.
  10. onepluskitty
    Froyo Apr 5, 2015
    onepluskitty , Apr 5, 2015 :
    Nope, didn't realise it was a Zipception, haha. Thanks :)
    mattfohs2006 likes this.
  11. Backflip
    Cupcake Apr 5, 2015
    Backflip , Apr 5, 2015 :
    100% agree, really wish it had double tap to sleep anywhere like the LG G3
  12. dharmeshkapasi
    Froyo Apr 5, 2015
    dharmeshkapasi , Apr 5, 2015 :
    No, you can't do that. CM and Oxygen can't be OTA-ed over one another, nor can you use CyanDelta to flash Oxygen over CM12. You will need to wipe and use the procedure laid out in the first post of this thread.
  13. dharmeshkapasi
    Froyo Apr 5, 2015
    You zip is corrupted. Re-downloading it should solve this.
  14. Johnmm
    Eclair Apr 5, 2015
    Johnmm , Apr 5, 2015 :
    I didn't do it and do not intend to. I thought this was our main update.
  15. Johnmm
    Eclair Apr 5, 2015
    Good plan of action.
  16. Maximus12
    Maximus12 , Apr 5, 2015 :
    Question for Oxygen users - does it give you control of the screen tint? An earlier CM used to let you adjust this yourself, but that feature was lost in later versions. I think the stock screen looks too washed out.
  17. Johnmm
    Eclair Apr 5, 2015
    People like you? No need to be a jerk.
  18. pratheep_s
    Froyo Apr 5, 2015
    Y
    yes.. working fine..
  19. giovnzcr
    Cupcake Apr 5, 2015
    giovnzcr , Apr 5, 2015 :
    How do I go back o CM11? I don;t like the internet performace of the oxygen. Please help me out
    Deactivated User likes this.
  20. abdulsalam9
    Donut Apr 5, 2015
