639
OxygenOS is here [Installation Guide]
  1. onisahkku
    Cupcake Apr 5, 2015
    Deactivated User likes this.
  2. paleswar
    Donut Apr 5, 2015
    paleswar , Apr 5, 2015 :
    Is CM12s officially available for through OTA for Indian customer?
    t4ww4b likes this.
  3. amandadam
    Honeycomb Apr 5, 2015
    amandadam , Apr 5, 2015 :
    Sorry to say that this thread has some really dumb posts.Noob city with asinine complaints.
    This thread has some really dumb *** questions,asked by people who don't know how to use Search and are just plain lazy.
    Don't mean to offend anyone but enough with the need for hand holding and spoon feeding.
    Flamingm0e likes this.
  4. sagarbalsari
    Ice Cream Sandwich Apr 5, 2015
    sagarbalsari , Apr 5, 2015 :
    Yes apparently Indian users will get ota for cm12 as said by Carl on twitter.
  5. captsakis
    Gingerbread Apr 5, 2015
    captsakis , Apr 5, 2015 :
    I used Wug's Bacon Root Toolkit and did everything ok
  6. Divyanshu93
    Eclair Apr 5, 2015
    Divyanshu93 , Apr 5, 2015 :
    Flashed it today morning. Now there was a wakelock which I managed to terminate and put my phone in deep sleep.
    The problem is when the screen is on, the battery drains faster compared to CM11S.
    BBS shows a 1% drain for 2 minutes of SoT while on CM11S it was 1% for 6 minutes of SoT. Is this a bug?
  7. aravipistha
    aravipistha , Apr 5, 2015 :
    Some thoughts after using Oxygen
    Poor battery life, especially idle battery drain of 15% overnight
    Other than that, everything else about the Rom is good. For people who've followed Paranoid Android will know what I'm trying to convey. There is obvious choice to flash CM12s when it does arrive. In a plain vanilla android, you dont have swipe right for quick settings, or touch quick settings icon to activate (for instance turning wifi on with one touch). The customizations are not plenty but definitely what I would expect minimal and is very different to stock android.. I didnt expect tons of features (and honestly even in CM11s I didnt use all of the customizations).. All of us have our likes for customizations and I think OOS in due time will address it.
    Privacy guard is a must and I dont know why there was at least no ap ops in the first release. Also a good camera app (api2). But OP have mentioned it is coming in a future release.. I'll come back to OOS once the battery life is good.. But definitely a subtle but good rom. I like the philosophy behind the design..
    reverenddak likes this.
  8. aslamdriver
    Donut Apr 5, 2015
    aslamdriver , Apr 5, 2015 :
    You can do it easily by adb push command. go to recovery and type command
    adb push OS.zip /sdcard/
    or simply put OS.zip on your otg pen drive and connect and copy to internal storage.
    Regards.
    psionandy likes this.
  9. Divyanshu93
    Eclair Apr 5, 2015
    I did the same mistake.
    My solution:
    I copied the zip file on my pendrive (formatted the pendrive in FAT32). Connected it to the phone with an OTG cable, started TWRP and mounted USBOTG. Then I went ahead and installed the rom from the usbotg folder. :)
    psionandy and umberto75 like this.
  10. coppola
    Cupcake Apr 5, 2015
    coppola , Apr 5, 2015 :
    Like the fact that this is as stock as it can get. Love that there are no themes.
    reverenddak and YagubZZ like this.
  11. ThePlainGamer
    ThePlainGamer , Apr 5, 2015 :
    did you unzip the file?
    There is the flashable zip in the first zip file
  12. ipankil
    Froyo Apr 5, 2015
    ipankil , Apr 5, 2015 :
    Anyone has an idea how to disable the smart splitted notification drawer on OxygenOS??
  13. OfferedSnow
    Cupcake Apr 5, 2015
  14. emirko
    Eclair Apr 5, 2015
    emirko , Apr 5, 2015 :
    Install failed!
    Finding update package...
    Opening update package...
    Verifying update package...
    E: failed to verify whole- file signature
    E: signature verification failed
    Instalation aborted.
    What goes wrong here? Unlocking process is quit complicated. :(
  15. Niels_Andersen
    KitKat Apr 5, 2015
  16. Dr sandeep
    Donut Apr 5, 2015
  17. DigitalAnarchy
    Jelly Bean Apr 5, 2015
  18. jokicha
    jokicha , Apr 5, 2015 :
    theres a list for known issues. that means its not exactly a finished product no?
  19. Ssx705
    Donut Apr 5, 2015
    Ssx705 , Apr 5, 2015 :
    When I try to open the clock this box pops up:
    Anybody know a fix for this?
    takahasimasahide likes this.
  20. swieprecht86
    Cupcake Apr 5, 2015
    swieprecht86 , Apr 5, 2015 :
    I havent found 1 to be the case...
