639
OxygenOS is here [Installation Guide]
  1. cedalone
    Jelly Bean Apr 5, 2015
    cedalone , Apr 5, 2015 :
    ...and now, your One is booting on TRWP, that's it? If yes, you wipe again (all exept internal storage) then you reflash Oxygen.
  2. pedrinhu97
    Cupcake Apr 5, 2015
  3. emirko
    Eclair Apr 5, 2015
    emirko , Apr 5, 2015 :
    No it's not unlocked. I thought this process with TWRP does it. Where is instruction to unlock OnePlus?
  4. jrcoakley83
    Donut Apr 5, 2015
    jrcoakley83 , Apr 5, 2015 :
    Okay, thanks. I will see what I can do.
  5. petin
    Cupcake Apr 5, 2015
    petin , Apr 5, 2015 :
    Here...in the installation instructions
    if you follow the steps, you should have no problem with the installation (make sure, that the recovery update checkbox is unchecked)
  6. cedalone
    petin likes this.
  7. madonion
    Eclair Apr 5, 2015
    madonion , Apr 5, 2015 :
    Did you not use the command fastboot oem unlock first? You need to use this command to unlock the boot loader before flashing TWRP.
    petin likes this.
  8. troyolson92
    Eclair Apr 5, 2015
    troyolson92 , Apr 5, 2015 :
    Flamingm0e is an obvious troll. Adds nothing and "flames" all. That's what happens with limited knowledge and no skill
  9. Donisky
    Cupcake Apr 5, 2015
    Donisky , Apr 5, 2015 :
    Pourquoi on n'envoie pas l'oxygène par e-mail. Ce serait plus cool. Sur le forum je vois les titres. Mais aucune pièce jointe.
    Je ne peux pas OUVRIR le Guide. Qui peut m'aider
  10. joshklee
    Cupcake Apr 5, 2015
    joshklee , Apr 5, 2015 :
    Thanks for the release! As stated in the release post about looking for input, integrating Xposed Framework into the OS would be a good, non-gimmicky addition.
  11. pascalwacker
    Cupcake Apr 5, 2015
    pascalwacker , Apr 5, 2015 :
    I have the same Issue. Any idea how to fix that?
  12. Stegge36
    Cupcake Apr 5, 2015
    Stegge36 , Apr 5, 2015 :
    Thanx.Instalation was not so easy for a beginner like me but now,finally it`s there.The OS seems to work faster than the CM11 with my OPO.Antutu Benchmark had almost 46000 Points.
    florian.dialer likes this.
  13. petin
    Cupcake Apr 5, 2015
    i dont think its complicated...if you learn that once, you will have never again problem with custom rom flashing. The only thing you need to unlocking is Android SDK, because you need the FASTBOOT command.
  14. sachinrathee
    Cupcake Apr 5, 2015
    sachinrathee , Apr 5, 2015 :
    I installed OxygenOS sucessfully. I swiped to install SuperSU too at the end. So when I rebooted the phone I got a notification to install SuperSU. I downloaded SuperSU from here : http://download.chainfire.eu/396/SuperSU/ and then rebooted in recovery mode. I flashed the SuperSU zip and it got installed successfully and the phone rebooted. But now the phone is stuck at the OxygenOS reboot logo since the past 15 minutes.
    Anyone has an idea what I should do?
  15. ZjM-Pyrrhos
    Eclair Apr 5, 2015
    ZjM-Pyrrhos , Apr 5, 2015 :
    Not sure if anyone asked this, but will there be an ota update?
  16. Ryymoo
    Gingerbread Apr 5, 2015
    Ryymoo , Apr 5, 2015 :
    Can't get it right with my Mac. Apparently adb and fastboot installted. When I check Developer mode/Debug on the phone and reboot in bootloader mode, the Terminal doesn't recognize it. Any idea or Mac step-by-step guide for a non-expert? Or is it possibile to flash without a computer, i.e. with an Android app on the phone.?
  17. Manideep007
    Cupcake Apr 5, 2015
  18. cedalone
    did you try the OS X toolkit? apparently you have a pb with no adb drivers in your mac. Anyway i think you should do it with windows (parallel desktop or bootcamp) because most of people use it , and like that you can find more help.
  19. jrcoakley83
    Donut Apr 5, 2015
    I was able to install OxygenOS but I'm not able to connect to the cellular network, any thoughts anybody?
    neyzen69 likes this.
  20. Deactivated User
    Apr 5, 2015
