638
OxygenOS is here [Installation Guide]
  1. MohitKumarRai
    Froyo Apr 7, 2015
    MohitKumarRai , Apr 7, 2015 :
    yeah, i did full wipe including dalvin, cache and system in it and then flashed oxygenOS
  2. Funk Wizard
    Lollipop Moderator Apr 7, 2015
    Funk Wizard , Apr 7, 2015 :
    Factory reset please, extract the flashable zip and md5 in the same folder and flash away
  3. backslash9
    Eclair Apr 7, 2015
  4. flameonfzn
    Gingerbread Apr 7, 2015
    flameonfzn , Apr 7, 2015 :
    Have you tried installing cm11s by toolkit
  5. lokesh3440
    Honeycomb Apr 7, 2015
    lokesh3440 , Apr 7, 2015 :
    Are you out of your mind ? This is a Closed Source OS specifically designed for One Plus. Always think before asking these silly questions.
    backslash9 and Deactivated User like this.
  6. rushabhbhatt
    Eclair Apr 7, 2015
  7. sachinrathee
    Cupcake Apr 7, 2015
    sachinrathee , Apr 7, 2015 :
    Well you pointed out almost everything there. Good job!
    I've noticed that new widgets installed from Play Store don't show up in the Widgets Drawer.
    miv3180 likes this.
  8. samit4uhere
    Eclair Apr 7, 2015
    samit4uhere , Apr 7, 2015 :
    For me it's worst battery life (post 3 full charge cycle), Battery on Oxygen is less than 3/4 of what I had in CM11.... :(
    Going to flash cm12 or back to cm11 by tonight.. I think OPO will NEVER let me SETTLE.
    While writing this I found out an issue:- U can't unlock ur phone even with power button if proximity sensor (top part of the phone) is covered (by hand or anything else)
    EDIT1: I have used facebook and messanger almost for 5-10 minutes in past 15 hrs, however it seems to be top battery consuming app (Even above the screen)....
  9. mmitkar
    Eclair Apr 7, 2015
    mmitkar , Apr 7, 2015 :
    Hi,
    Please mention the steps on how to install fastboot and ADB as well in a simpler way.
  10. flameonfzn
    Now all you need to do is flash supersu. And use textdroid app to change your dpi to 350.
  11. flameonfzn
    No need just install toolkit.
    Just use a toolkit. It's a single application.
    http://forum.xda-developers.com/oneplus-one#root
    Here you will found a video on how to use it and also the toolkit itself. It's too easy.
    For drivers.. Download this software.. Install.. Open and attach your oneplus to your pc. Download and install drivers.
    http://adbdriver.com/upload/AdbDriverInstaller.exe
    Finally to isntall oxygen os see this video.
    calipo69 likes this.
  12. gautham812
    Cupcake Apr 7, 2015
    gautham812 , Apr 7, 2015 :
    copy oxygenos zipfile to pendrive, use otg and connect to pendrive and press voldown+power button
    miv3180 likes this.
  13. saucedod
    Froyo Apr 7, 2015
    saucedod , Apr 7, 2015 :
    Ohhhhhh burn! Ouch, hahaha! Cornball!
  14. rishiantique
    Cupcake Apr 7, 2015
    rishiantique , Apr 7, 2015 :
    Hey I installed TWRP but i dont understand how to root my phone. Can you pls help me with steps pls
  15. fireboy3x
    Eclair Apr 7, 2015
    fireboy3x , Apr 7, 2015 :
    I just would like to know WHEN is your "easier, more automated solution" going to be available.
  16. Niels_Andersen
    KitKat Apr 7, 2015
    Niels_Andersen , Apr 7, 2015 :
    And the Cupcake said to the Doughnut:"If you don't shut up, I'll call my big brother, he's an Éclair" ;-)
    miv3180 likes this.
  17. lokesh3440
  18. ratz_99
    Cupcake Apr 7, 2015
    ratz_99 , Apr 7, 2015 :
    Updated Oxygen OS.. Seems to be smooth till now. However I don't see the option for active exchange to install my office emails. Any suggestions?
  19. Nimit4
    Jelly Bean Apr 7, 2015
    Nimit4 , Apr 7, 2015 :
    Another stupid issue:
    I can't call someone but someone can me.
    When i dial number it just said 'Call end'
    miv3180 likes this.
  20. musikele
    Cupcake Apr 7, 2015
    musikele , Apr 7, 2015 :
    how do you do this?
    other question, if I install the oxygen rom now, do I have to wipe data again? Bootloader is already unlocked.
