639
OxygenOS is here [Installation Guide]
  1. Xyain
    Eclair Jul 18, 2015
    Xyain , Jul 18, 2015 :
    Isn't CM 12.1 not stable yet?
    arundas5959 likes this.
  2. arundas5959
    Ice Cream Sandwich Jul 18, 2015
    arundas5959 , Jul 18, 2015 :
    Yes, CM 12.1 is quite stable! I have the latest version in my OPO. No problem so far!
  3. annrohit
    Cupcake Jul 18, 2015
  4. arundas5959
    It is already there in the OP site. Follow the installation guide.
  5. annrohit
  6. XAPAKTEP
    Eclair Jul 18, 2015
  7. vplawat
    Cupcake Jul 20, 2015
    vplawat , Jul 20, 2015 :
    This is nice info!!
  8. dbamaro
    Froyo Jul 20, 2015
    wbritao likes this.
  9. jdneilso
    Gingerbread Jul 23, 2015
    jdneilso , Jul 23, 2015 :
    One major advantage to installing Oxygen OS is that you also install TWRP as part of the process. With TWRP you can backup your existing installation and restore it whenever you want. I've been able to switch back and forth between Oxygen OS and CM 12S. I just keep the latest backup of each on my phone and restore it when I want to switch.
    morgoth94 likes this.
  10. shuj420
    Honeycomb Jul 23, 2015
  11. Ymfms
    Froyo Jul 23, 2015
  12. talgolds
    Cupcake Jul 25, 2015
    talgolds , Jul 25, 2015 :
    hi did you find any solution?
    היי אבישי האם מצאת פתרון לבעיה אם כן אשמח לשמוע יש לי את אותה בעיה
    תודה
    טל
  13. tanveerkhan9
    Eclair Jul 26, 2015
  14. djames2897
    Froyo Jul 26, 2015
    djames2897 , Jul 26, 2015 :
    Apologies if this has been asked before but don't want to start a new thread. How regular are OP1 updates? Are they similar to the Nexus releases? I suppose it's likely to change with OxygenOS, seems similar to stock, but if anyone has any info, would be much appreciated!
  15. Dsjm
    Froyo Jul 27, 2015
    Dsjm , Jul 27, 2015 :
    Have decided not to flash Oxygen on my OPO but will get it with a new OP2. I like Cyanogen & have no complaints so this approach makes sense to me.
  16. Shrapnelist
    Jelly Bean Jul 27, 2015
    Shrapnelist , Jul 27, 2015 :
    this is a new rom so updates may roll out after OP2 is released, the updates will be recovery flashable I think. Most OP1 users flash custom roms so third party support is there. Updates are for official stock cyanogen os and oxygen os bit slower than nexus.
  17. Narenssec
    Cupcake Jul 27, 2015
  18. JOKERxl
    JOKERxl , Jul 27, 2015 :
    I really should have never updated to Lollipop... Battery decay within a day. I think I will reinstall CM11 and wait until CM12S arrives.
  19. ceejig
    ceejig , Jul 27, 2015 :
    So far, despite the fact that I am curious to try out the Oxygen OS, I haven't because CM12 has been working great just for me. I still haven't been motivated to switch, maybe a few bells and whistles will be added to the OS in the not too distant future to motivate a switch.
  20. ceejig
    I have heard this a lot, that is why I have still stuck to my CM12. As the saying goes,"if it ain't broken, don't fix it." :)
