638
OxygenOS is here [Installation Guide]
  1. jstepa
    KitKat Nov 3, 2015
    jstepa , Nov 3, 2015 :
    4 more posts to go ;)
  2. camilo.mateus001
    Donut Nov 3, 2015
    camilo.mateus001 , Nov 3, 2015 :
    Right after installing TWRP unplug the phone (WITHOUT REBOOTING) and press the power and volume down buttom at the same time
    the phone will turn off
    press the volume down and power buttom once again the phone will be forced to boot into TWRP
  3. smallzoo
    Cupcake Nov 5, 2015
    smallzoo , Nov 5, 2015 :
    how easy is installing oxygen instead of cyogen.. do you need to be a real techie
  4. Trevizanzan
    Froyo Nov 5, 2015
    Trevizanzan , Nov 5, 2015 :
    Hi all!
    2 simple questions:
    1 - Can I install OxygenOs 2.1 on my One Plus One? (Android 5.1)
    2 - In this software version are present all the features of the OP2 like the dark mode, ecc?
    Thank you very much!
  5. Tuamtuam
    Gingerbread Nov 5, 2015
    Tuamtuam , Nov 5, 2015 :
    Did you read the info under SPOILERS in the first post?
    Have you done any flashing, rooting or manual install in adb or fastboot before?
    I wouldn't say you have to be a real techie, but you would need some time to carefully read and follow the instructions.
    I have done it just this evening onto my friend's OPO, went very smoothly, but I have done similar stuff before. I did teach myself how, though!
    There are excellent guides on these forums on all the steps you would need to take to get OxygenOS onto your OPO, here is perhaps the most comprehensive one about general tinkering procedures (not Oxygen specific, but the methods are the same) so far: https://forums.oneplus.net/threads/...lashing-recovery-roms-kernels-rooting.291274/ remember to like his work if it helps you.
  6. Gnocchyaldente
    Cupcake Nov 6, 2015
    Gnocchyaldente , Nov 6, 2015 :
    Hello
    I have tried replacing cyanogen with oxygen on the advice of oneplus overheated because my phone but the phone still hangs on the oxygen logo and then nothing a little help please
    ONE_12_A.01_15600(1)zip
    ONE_12_A.01_15600.zip(1).md5
  7. jstepa
    KitKat Nov 6, 2015
    jstepa , Nov 6, 2015 :
    This file is all you need:
    https://s3.amazonaws.com/oxygenos.oneplus.net/ONE_12_A.01_150827.zip
    Don't put the .md5 in the same directory (I don't know why)
    Uncheck the "Zip file signature verification" from TWRP before flashing
    Source:
    https://forums.oneplus.net/threads/update-oxygenos-1-0-3-with-the-latest-stagefright-patches.354409/
  8. Gnocchyaldente
    Cupcake Nov 6, 2015
    i do that and i have the same problem
    thanks for you help
    i put .md5 where?
    i put it in the racine
  9. jstepa
    KitKat Nov 6, 2015
    You don't need that .md5 file at all, just the ROM file.
    Did you make an clean flash, wipe everything but the internal storage and otg?
  10. Shabbir Ahmed
    Cupcake Nov 6, 2015
  11. Gnocchyaldente
    Cupcake Nov 6, 2015
    what is the command to do that in twrp i ll do that
  12. jstepa
    KitKat Nov 6, 2015
  13. jstepa
    KitKat Nov 6, 2015
    Just a reminder that this will wipe all apps etc. so backup if needed, before you do this!
    Boot to recovery
    - Wipe
    - Advanced wipe
    - Select everything but internal storage and otg
    - Swipe to Wipe
    - Flash ROM
    - Wipe Dalvik and cache
  14. Shabbir Ahmed
    Cupcake Nov 6, 2015
    Shabbir Ahmed , Nov 6, 2015 :
    give me the link where i can get oxygen os for oneplus x???
  15. jstepa
    KitKat Nov 6, 2015
    I gave you the category link, ask there :confused:
    Shabbir Ahmed likes this.
  16. Shabbir Ahmed
    Cupcake Nov 6, 2015
  17. jstepa
    KitKat Nov 6, 2015
    Trying to meet your 5 post quota, right?
    One more, you can do it ;)
  18. Shabbir Ahmed
    Cupcake Nov 6, 2015
    no man.. seriously i need oxygen os for oneplus x.. bcoz i m a new oneplus user. i dont know how and where i get o2 os..
  19. jstepa
    KitKat Nov 6, 2015
    I'll say this once again, if you have OnePlus X (not OnePlus One) go to this category and post there:
    https://forums.oneplus.net/forums/X/
  20. pbergonzi
    KitKat Nov 9, 2015
    pbergonzi , Nov 9, 2015 :
    Your phone came with OxygenOS 2. There is an update now also. Check the Stickies in the forums.
