638
OxygenOS is here [Installation Guide]
  1. pbergonzi
    KitKat Nov 9, 2015
    pbergonzi , Nov 9, 2015 :
    Your phone came with OxygenOS 2. There is an update now also. Check the Stickies in the forums.
  2. hemant.ajal
    Cupcake Nov 11, 2015
  3. Deactivated User
    Nov 11, 2015
  4. Igor San Vicente Uranga
    Igor San Vicente Uranga , Nov 11, 2015 :
    one question, how can this be done, if you have black screen, and you cannot do anything with the terminal, is there any way to do it without doing anything with the terminal?
  5. Deactivated User
    Nov 11, 2015
    jstepa likes this.
  6. jstepa
    KitKat Nov 11, 2015
  7. Deactivated User
    Nov 11, 2015
    jstepa likes this.
  8. jstepa
    KitKat Nov 11, 2015
    jstepa , Nov 11, 2015 :
    Yes I agree 1.0.3 sucks, that's why I'm not using this and can't tell you settings.
    I suggest that you try Sultan's Lollipop or Marshmallow ROM, the camera is unbelievable.
  9. Deactivated User
    Nov 11, 2015
    jstepa likes this.
  10. jstepa
    KitKat Nov 11, 2015
    Well it seems that you are stuck with this :(
    Or if you are willing to use two ROM's with multirom, you could always change ROM's when you need to use the Oxygen camera...
  11. Deactivated User
    Nov 11, 2015
    jstepa likes this.
  12. Ehuezo63
    Cupcake Nov 14, 2015
  13. jstepa
    KitKat Nov 14, 2015
    jstepa , Nov 14, 2015 :
    No OTA for Oxygen OS
  14. sarvatrajit
    Froyo Nov 14, 2015
    sarvatrajit , Nov 14, 2015 :
    Js
    I had a question -- how do I root my device again? I had it rooted earlier but after flashing Oxygen I seem to have lost root access.
    Do I need to simply flash SU.zip?
    Thanks in advance.
  15. jstepa
    KitKat Nov 14, 2015
    Yes, flash SU in TWRP, it should give back root access...
  16. sarvatrajit
    Froyo Nov 14, 2015
    Thanks! Did that and it worked. :D
    Although, I seriously preferred CM12 to Oxygen OS -- Gah.
  17. jstepa
    KitKat Nov 14, 2015
    So why flash Oxygen OS at all? ;)
  18. sarvatrajit
    Froyo Nov 14, 2015
    Haha, just wanted to give it a shot once.
    I even got all my backup apps downloaded and everything -- then realised then screen brightness cannot be controlled from sliding the status bar anymore and that's what sealed it for me.
    Will go back to CM first thing tomorrow! :)
  19. jstepa
    KitKat Nov 14, 2015
    Good for you :)
    Helen (staff) said that the update for OPO is "near":
    https://forums.oneplus.net/threads/oxygenos-q-a-with-helen.403960/
    So atleast I will try this again then...
  20. ValentinasKin
    Cupcake Nov 18, 2015
    ValentinasKin , Nov 18, 2015 :
    Is it works only on oneplus one? I have a present - Oneplus X from china and I want to have all google services and etc. So I need to change Hydrogen to Oxygen operating systems. Do it fits too? or I need to wait for official release for my phone? Help me with that :)
