Download OxygenOS
HERE
Download Feedback App
HERE
Note: You’ll need to enable installations from unknown sources (settings > security) in order to install the feedback app on OxygenOS.
Please make sure all your data and files are backed up before commencing. Flashing OxygenOS onto CM does require a system wipe, so you will lose all of your data. We are actively working on an easier, more automated solution soon to be available, but for now the build must be flashed manually.
Please proceed only if you are confident in your abilities to flash a custom ROM. This guide exists to help you flash OxygenOS, but things can still go wrong if not followed correctly. While rooting and flashing will not void your OnePlus warranty, any damage caused by improper flashing is not covered under warranty.
The following instructions assume you have
Fastboot and ADB installed.
Step 1
You first need to flash a recovery onto your device. We recommend using
TWRP. Please download the recovery image to your computer. You can follow
their instructions to flash recovery, or you can reference these steps:
- Boot into fastboot mode. You can do this on your OnePlus One by holding down the power button and the volume up button. When you see the fastboot logo, connect your device to your computer.
- In your terminal window, find the folder where you put the recovery image and run the following commands:
fastboot oem unlock (You can skip this step if your phone’s bootloader is already unlocked).
fastboot flash recovery <recovery.img>. Image file should be the TWRP recovery image.
fastboot reboot
You should now have the recovery installed.
Step 2
Copy oxygenos_1.0.0.flashable.zip to your phone. On a Mac, you can use
Android File Transfer.
Step 3
Boot into recovery. You can do this on your OnePlus One by holding down both the volume down key and the power button.
Step 4
Once you are in the recovery interface, the first thing you want to do is a factory reset. Again, you will lose all your data so please make sure you have backed up everything before doing this.
Step 5
After the wipe, go to install and find oxygenos_1.0.0.flashable.zip. Confirm flash. This will flash OxygenOS onto your device.
Step 6
After the flash succeeds, you can reboot the device, which will take you to the new OxygenOS. Enjoy!
If you find yourself wanting to rollback to CM, Make sure you have TWRP or CM recovery on the device. Another factory reset will be needed before flashing unfortunately so make sure you backup all of you data.
Never Settle.
