638
OxygenOS is here [Installation Guide]
  1. shubhayud
    Froyo Apr 4, 2015
    shubhayud , Apr 4, 2015 :
    Issue is:
    1. I soft bricked OPO while reverting from Oxy to CM11
    2. Fastboot and TWRP are accessible.
    3. Didnt take a backup
    4. PC doesnt detect the device in fastboot/twrp
    5. "fastboot devices" still works though.
    I want to return to CM 11 safely, either via some safe toolkit or enroute Nightly.
    Need suggestion/help
  2. yamcha67
    Gingerbread Apr 4, 2015
    yamcha67 , Apr 4, 2015 :
    Awesome! So far loving it, just flashed it on my OPO. This to me is far better than CM12 and is noticably faster than the CM12 nightly I flashed yesterday.
    Well done guys. Feels fairly polished just like a real nexus experience.
  3. Atreide
    Eclair Apr 4, 2015
    Atreide , Apr 4, 2015 :
    read this : http://twrp.me/devices/oneplusone.html
  4. renegadomota
    Donut Apr 4, 2015
    renegadomota , Apr 4, 2015 :
    Awesome! Sounds pretty stable. Great work from Oxygen team. Now we just have to wait for CM to do the same. Thanks.
  5. mem101296
    Donut Apr 4, 2015
    mem101296 , Apr 4, 2015 :
    I love the ROM! A word of advice, create your own apps, including the following
    -weather
    -launcher
    -gallery
    -texting
    -file manager
    Also allow the Google Apps to be removed without root. Thanks!
    miv3180 likes this.
  6. miv3180
    Froyo Apr 4, 2015
    miv3180 , Apr 4, 2015 :
    you're hopeless bro. Have a nice day. Do me a big favore, DON'T REPLY!!!
  7. madelainesanta
    Eclair Apr 4, 2015
  8. ddbobade
    Honeycomb Apr 4, 2015
  9. Pavankalyan
    Pavankalyan , Apr 4, 2015 :
    in developer options uncheck the update CM recovery option and then flash recovery.img and reboot u will get the new recovery
  10. cormasco
    Cupcake Apr 4, 2015
    cormasco , Apr 4, 2015 :
    I installed Quickpic from app store for gallery app
    For callender widgets I use Event Flow
    I installed Google Messenger for texts because I dislike Hangouts.
  11. Joey_all_the_way
    Eclair Apr 4, 2015
  12. miv3180
    Froyo Apr 4, 2015
    Yeah!!! We want a slim ROM. I hate been unable to remove lots of apps I don't use. Let the user choose his apps. We want basic gapps.ROm should be no more than 500MB.
  13. flameonfzn
    flameonfzn , Apr 4, 2015 :
    okay so you have the OPO toolkit but your pc isn't detecting your phone ? that's the only problem right.
    okay so try this ... download this software
    http://adbdriver.com/downloads/
    then attach your OPO to your pc. See if it detects it this time. if it does .. just install the cm11s from the OPO toolkit as usual.
    *ediT* i forgot to mention that you should install that software after downloading and then open it .. then attach your phone to install drivers.
    put your phone in fastboot mode when you attach it.
  14. fairmount
    Cupcake Apr 4, 2015
  15. mgarf
    Cupcake Apr 4, 2015
    mgarf , Apr 4, 2015 :
    so does this mean the promised "ok, snapdragon" will becoming to OxygenOS?
  16. Fabman
    Cupcake Apr 4, 2015
  17. shubhayud
    Froyo Apr 4, 2015
    thanks. downloading the driver. But i have hadd never used any toolkit for flashing. Which toolkit you are referring to?
  18. hilmiuchiha8
    Cupcake Apr 4, 2015
  19. eastrader
    Cupcake Apr 4, 2015
    eastrader , Apr 4, 2015 :
    Yes.. all gone bye bye, that is why you need to do a backup before starting..It will make it like when you opened the box for the very first time and power up.
  20. miv3180
    Froyo Apr 4, 2015
    Try and reflash Oxigen OS again. Your bootloader has been upgraded, that's why you can't go back to kitkat. good luck.
