358
OxygenOS Open Beta 1 (Android O) for the OnePlus 5T
Thread Status:
Not open for further replies.
  1. dnyaneshwar Patekar
    Froyo Dec 30, 2017
    dnyaneshwar Patekar , Dec 30, 2017 :
    Updated To Beta 1 Successfully .
    It Took 30 mins for entire process .
    Thank You Team One Plus .
    I will keep Posting Bug Reports In The Requested Bug Report Page .
    As of now ,I am using it for last 45 mins .
    1) Running Super Smooth .
    2) Camera is same as earlier
    3) Assistive Lighting is gone - Not a big deal though
    4) Overall UI Looks Clean ,I can say it's better than my Pixel XL right now .
    5) Voice Calls Working Perfectly Well
    6) SMS Working Well .
    chinnpao and Paul013 like this.
  2. omar460
    Eclair Dec 30, 2017
    omar460 , Dec 30, 2017 :
    I'm not trying to undermine you, but can anyone confirm this, I really hate these emojis
  3. adhithya.raman
    Donut Dec 30, 2017
    adhithya.raman , Dec 30, 2017 :
    JelleZon likes this.
  4. omar460
    Eclair Dec 30, 2017
    Regarding if I go to stable oreo in the future after this beta
  5. Funk Wizard
    Moderator Moderator Dec 30, 2017
    Funk Wizard , Dec 30, 2017 :
    Its the sticky post, post 2 after the opening post
  6. dnyaneshwar Patekar
    Froyo Dec 30, 2017
    From beta to stable you won't be able to go without data wipe .
    So simple answer is no .
    But Here is Solution for you .
    1) Update to Beta 1 & use along with beta upcoming updates
    2) by the time one plus releases Stable version Beta will also be super stable by that time .
    3) At that moment you can take decision .
    4) If required take recovery backup
    5) restore in stock stable Oreo ,that should get everything running as it is .
    I hope this helps .
  7. sheppy1
    Gingerbread Dec 30, 2017
    sheppy1 , Dec 30, 2017 :
    I did a quick Google and others reported you can download the full OS Zip when the final Oreo release becomes available and Flash it over the beta to return to a the stable OS channel and this doesn't wipe your data.
    However! I've never tried it so I can't confirm if they're talking rubbish or not
    gotshoaib likes this.
  8. dnyaneshwar Patekar
    Froyo Dec 30, 2017
    that will work .
    Reason : You are flashing Oreo from Oreo .
    So you won't be losing data logically
    JelleZon and gotshoaib like this.
  9. I1513693401660
    Donut Dec 30, 2017
  10. sheppy1
    Google it! My God! This question is asked every 5 messages!
    JelleZon, amxim1, gotshoaib and 2 others like this.
  11. G_sascha_boewes_SMiY
    Froyo Dec 30, 2017
  12. nunovpc
    Eclair Dec 30, 2017
    nunovpc , Dec 30, 2017 :
    Super quick installation process and it really runs smooth without any major issue. seems stable!
  13. Lucky M. Nelson
    Froyo Dec 30, 2017
    Lucky M. Nelson , Dec 30, 2017 :
    I am so glad I can finally type fast again without worrying about accidentally closing the damn application! Glad this is fixed with the O update!
    gotshoaib and ldwgvnfnstr like this.
  14. virendrag
    Cupcake Dec 30, 2017
  15. gamerxsoft
    Honeycomb Dec 30, 2017
    gamerxsoft , Dec 30, 2017 :
    How it has been implemented?
  16. G_sascha_boewes_SMiY
    Froyo Dec 30, 2017
    G_sascha_boewes_SMiY , Dec 30, 2017 :
    You don't loose your data if you download and Flash via recovery! I did that and everything is still there
  17. MentalDraco
    Marshmallow Dec 30, 2017
    MentalDraco , Dec 30, 2017 :
    I presume the navbar hides? Not sure what else.
    the_reckoner likes this.
  18. BrainsCollector
    BrainsCollector , Dec 30, 2017 :
    I will wait for final release to use it but I just want to ask, if there is implemented gesture based navigation like there were leaks about it ?
  19. Z1511711724508
  20. gamerxsoft
    I mean when you have to back after typing then what to do? Again swipe up to bring nav bar?
