91
OxygenOS Open Beta 1 (N) for OnePlus 3T
  1. G_Hugo_Scaramal_NlkK
    Eclair Dec 31, 2016
    G_Hugo_Scaramal_NlkK , Dec 31, 2016 :
    Hi, I just installed the Beta 1 and was trying to find a way to confirm the installation, what is the build number for the Beta 1?
    I have installed Beta 1 through adb/sideload and I thought it would wipe out all my data and start fresh, but instead it kept all data, everything. Not that this is a bad thing, but I just want to confirm Beta 1 is installed.
    I was running the leaked the Nougat Oxygen OS.
  2. Humdeep
    Donut Dec 31, 2016
    Humdeep , Dec 31, 2016 :
    Not long had my OP3T, upgraded to the beta this morning and loving all the changes!
    Just a quick question, does anyone know if there is an easy way to change the slider? My prefered set up would be Loud, Vibrate, and Silent...as I never use DND.
    Cheers.
    dbau071101 likes this.
  3. GC1900
    Gingerbread Dec 31, 2016
    GC1900 , Dec 31, 2016 :
    Wow amazing ! OnePlus kept their promise of releasing the Nougat update for the 3T device this year ! Makes it finally worthwhile for having invested into the phone ! A New Year Gift for all the customers of the 3 and 3T device !
    inffy and fricy81 like this.
  4. Humdeep
    Donut Dec 31, 2016
    My build number for the beta is ONEPLUS A3003_28_161229.
    Hope this helps.
  5. Sun90
    Starting Point Expert Community Expert Dec 31, 2016
    Sun90 , Dec 31, 2016 :
    Check the kernel version in About phone.
  6. G_Hugo_Scaramal_NlkK
    Eclair Dec 31, 2016
    Great, my build number is the same.
    Thank you both.
  7. donalgodon
    Ice Cream Sandwich Dec 31, 2016
    dbau071101 and Sahilkum like this.
  8. Krishna2142
    Honeycomb Dec 31, 2016
  9. arnoakavdb
    Cupcake Dec 31, 2016
    arnoakavdb , Dec 31, 2016 :
    i dirty flash it over beta 1 that i dirty flash over last stock,everything running smooth.thank for the new year hier[e]1f609[/e]
  10. donalgodon
    donalgodon , Dec 31, 2016 :
    What's the build number of the Release build from today?
  11. sgmtnbike
    sgmtnbike , Dec 31, 2016 :
    lol, I know. I'm just saying that it shows"LTE" now vs. 4G. .. Which is better as a perception to everyone else that doesn't get it
    NeoHQQ likes this.
  12. greylee
    Donut Dec 31, 2016
    greylee , Dec 31, 2016 :
    this forum is so messy... why the moderator can't separate the segment for OP3T and OP3 ? so ppl don't get wrong for asking or downloading.
    for indonesia, download "opera VPN" apps via playstore, set region to german and you will get the OTA update notice in setting.
  13. BetVer
    Froyo Dec 31, 2016
    BetVer , Dec 31, 2016 :
    IMO it already was, let's be honest, most people who are making such a big fuss about the Android N update are either clueless about what changes it would actually bring, or will not have such critical need for it. They will be happy about it for 2 days, then move on to the next thing to be unsatisfied about.
  14. Gerald_Haniel
    Froyo Dec 31, 2016
    Gerald_Haniel , Dec 31, 2016 :
    This is how you downgrade/revert back to OOS 3.5.4...
    Requirements:
    Minimal adb and fastboot
    Latest twrp recovery (Rename to twrp.img)
    Latest stock recovery (Rename to stock.img)
    Official 3.5.4 flashable zip file from oneplus site (Rename to rom.zip)
    Steps are as follows
    1)Unlock Bootloader (Will wipe data and u have no other go)
    To do this
    *Download and extract minimal adb and fastboot
    *On the phone go to Settings>About Phone and keep tapping build number until you unlock developer options
    *Now go to settings>developer options and check enable oem unlock
    *Go to adb folder
    *Copy the rom zip file, twrp and stock recovery to this folder
    *Right click in any open space of the adb folder and select "open command window here"
    *Now connect the phone in fastboot mode (google it) to the PC
    *In command window type "fastboot oem unlock"
    *It will ask for confirmation on phone, using volume buttons navigate to Yes and press the power button
    *Enter fastboot mode again
    *Now flash twrp recovery using commands "fastboot flash recovery twrp.img"
    2)Enter into Twrp (Do not swipe to allow modifications)
    *Select Keep system read-only
    *Go to Advanced>adb sideload
    *Connect the phone with usb and on the PC type "adb sideload <drag the rom.zip file over here>" and press enter
    (There is a space after "sideload"... Dont forget to leave that space or else you will have errors)
    *The sideload will begin and the rom will be flashed... It will take more than 10mins
    *Wipe cache, data, dalvik/arm cache
    *Then in twrp go to the power menu and reboot to bootloader
    3)Now again enter into fastboot mode
    *Flash stock recovery using the same command used earlier but instead of twrp use stock as in "fastboot flash recovery stock.img"
    *After u get 'success' message on screen enter the command "fastboot oem lock" (To lock the bootloader)
    *On the phone again select Yes using volume buttons and select using the power button)
    *Now your phone will reboot within a while
    You are now back to stock official 3.5.4
    Warning: During this process you will lose your entire data... And sorry there is no other way to downgrade... This is your only shot....
    PS: Do hit the thanks button if I could help you... It will not cost a penny...
  15. raja.d
    raja.d , Dec 31, 2016 :
    both 7.0...
  16. donalgodon
  17. inffy
    KitKat Dec 31, 2016
    inffy , Dec 31, 2016 :
    It will. That is the point
  18. flycharlles78
    Eclair Dec 31, 2016
    flycharlles78 , Dec 31, 2016 :
    What is the deal in having a LTE or a 4G logo? I guess LTE and 4G are the same. Could you please clarify if you can to me?
  19. inffy
    KitKat Dec 31, 2016
    4g=LTE
    otto2 and flycharlles like this.
  20. g_au
    Eclair Dec 31, 2016
    g_au , Dec 31, 2016 :
    I see it no different to google's beta programme which I was enroled in permanently and if this beta 1 release is anything to go by I think i'll be sticking to it too as it doesn't feel unfinished in any way.
    inffy likes this.
