71
OxygenOS Open Beta 10 for the OnePlus 7 Pro and 7
  1. Swejuggalo
    OnePlus 9 Series Expert Community Expert Mar 20, 2020
    Swejuggalo , via OnePlus 7 Pro , Mar 20, 2020 :
    You can always grab it yourself. Links are listed in this Telegram channel.
    OnePlus[e]2122[/e]
    Everything OnePlus #NeverSettle
    Not endorsed by OnePlus
    https://t.me/OnePlus
    (open up with Telegram app)
    Mortalic likes this.
  2. B1574358598793
    Donut Mar 20, 2020
    B1574358598793 , via OnePlus 7 , Mar 20, 2020 :
    Change to waterOS
    akks likes this.
  3. Mortalic
    Eclair Mar 20, 2020
    Mortalic , via OnePlus 7 Pro , Mar 20, 2020 :
    thanks a lot... I used the oxygen updater.
  4. akks
    Lollipop Mar 20, 2020
  5. G_ik1llpeeple4fun_KWAF , via OnePlus 7 Pro , Mar 21, 2020 :
    G_Gaurav_Sharma_IvaQl
    link not available
    search on a particular apk mirror site and you'll find the even newer version ( OnePlus launcher 4.3.5). Which i already installed and am now running perfectly fine with the new oxygen beta 11 [e]1f440[/e][e]1f44d[/e].
    I was told by someone via private msg I can't post 3rd party links as it's against the rules so i can only hint at how to get the apk now. I don't want to cause any forum violations. But i can say if you find the apk mirror site and get it from there that it will install and work flawless [e]1f44c[/e]. Good luck ;-)
    G_Gaurav_Sharma_IvaQl likes this.
  6. G_Gaurav_Sharma_IvaQl
    Cupcake Mar 21, 2020
    G_Gaurav_Sharma_IvaQl , Mar 21, 2020 :
    thanks is beta 11 is good to install now ??
  7. G_ik1llpeeple4fun_KWAF , via OnePlus 7 Pro , Mar 21, 2020 :
    thanks is beta 11 is good to install now ??​
    You're welcome. Yes beta 11 installed and works fine for me. The new live caption feature is excellent AND if you edit your quick setting tiles you can add a tile just for live caption [e]1f440[/e]. This way you can enable or disable it when you pull the notification shade down with ease [e]1f44d[/e].
    And if you don't want to wait for the OTA beta 11 to notify you, go to an
    android sage site (which i won't properly link to avoid any violation lol)
    and download the global oxygen beta 11 from there (for international variants of OnePlus 7 pro). And then go to settings, check for updates, and when it says beta 10 is up to date - hit option for local upgrade and manually pick beta 11. You have to go in file manager 1st and then go in download folder and move beta 11 from download folder, to internal storage. Do not put in any folder then the local upgrade option finds it and installs it in 10 mins [e]1f44d[/e].
  8. tarun17
    Gingerbread Mar 21, 2020
    tarun17 , via OnePlus 7 Pro , Mar 21, 2020 :
    Hi developers,
    Thank you for providing the timely update.
    I am facing issue of face unlock, front camera is not popping out for face unlock. - issue gets repeated alot.
    To solve this issue:
    For this I have to open the security and then go for face unlock and don't do anything over there just enter phone password to unlock settings and it again starts working.
    Request you to please provide a suitable solution or if it a bug please address this in future updates.
    Steps already performed are:
    1. Restart
    2. Clear cache
    3. Safe mode
  9. G_Gaurav_Sharma_IvaQl
    thanks [e]1f60a[/e]
  10. Salman Lodhi
    Froyo Mar 21, 2020
  11. Bhargava Teja
  12. Swejuggalo
    OnePlus 9 Series Expert Community Expert Mar 21, 2020
  13. Bhargava Teja
  14. K1583543972482
  15. samedina4
    samedina4 , via OnePlus 7 Pro , Mar 21, 2020 :
    I love the new OxygenOS Open Beta 11, it fixed the voicemail problem I was having with Beta 10. Voicemail app kept crashing when I was trying to play the message. Thank you to the beta team for fixing this issue! keep up the hard work.
  16. Mrhodes19904
    Cupcake Mar 22, 2020
  17. G_ik1llpeeple4fun_KWAF , via OnePlus 7 Pro , Mar 22, 2020 :
    Bubbles is an upcoming android 11 feature for text msg's. Basically it's copying facebook messeger when it shows a contact bubble overlay on your screen. Not sure how android notification priority works.
    Mrhodes19904 likes this.
  18. Mrhodes19904
    Mrhodes19904 , via OnePlus 7 Pro , Mar 22, 2020 :
    Thank you
