245
OxygenOS Open Beta 10 (N) for OnePlus 3
  1. Kruemelfelix
    Honeycomb Dec 30, 2016
    Kruemelfelix , Dec 30, 2016 :
    Try another Camera App from the PlayStore. I don´t have such issues with beta 10
  2. Sai Krishna Thorata
    Ice Cream Sandwich Dec 30, 2016
  3. Uncle timmy
    Gingerbread Dec 30, 2016
    Uncle timmy , Dec 30, 2016 :
    Try this from the Fido site.
    Android is available on many devices and different versions exist in the market. Some of the names and information or settings below may vary depending on the device you have. This guide was made to provide instructions on as many devices and versions of the Android OS as possible starting from Android version 2.0.
    • Tap on Settings > Wireless & Networks > Mobile Networks > Access Point Names;
    • Once on the APN screen, press the Options button on the device;
    • Tap on New APN
    • Enter a name into the APN Name field.
    • Please insert the following APN settings:
      APN Settings:
      • APN: Fido-core-appl1.apn
      • If you have a LTE device, use the following setting: LTEMOBILE.APN
      MMS (Picture & Video Messaging Settings):
    • Leave the following fields blank: Proxy, Port, User Name, Password, Server
    • Press the Options button on your device, tap on Save in order to save the APN settings.
    • Restart the phone and try browsing the Internet.
    NOTE: The created APN will show up on the APNs screen. To activate the APN, tap on the radio button located in front of APN.
  4. Kruemelfelix
    You can´t use data from Android 7 for Android 6. Even not your internal storage because of f2fs
  5. F_Abhinav_Reddy_JmlG
    Froyo Dec 30, 2016
  6. Kruemelfelix
    Yes it´s so easy. Or you wait till tomorrow to get the official stable build and so you can save your internal storage.
  7. Sai Krishna Thorata
    Sai Krishna Thorata , Dec 30, 2016 :
    Note: If you flash this Open Beta build, you’ll receive Open Beta OTAs (but not official OTAs). You’ll need to manually (clean) flash back to our official builds to continue receiving official OTAs. Rolling back to official OxygenOS versions require wiping data and cache.
  8. Shrikant23
    Donut Dec 30, 2016
    Shrikant23 , Dec 30, 2016 :
    And how to go back to official OxyOS????
  9. Kruemelfelix
    Clean flash back. Wipe everything if you want to go back to 3.2.8 or wipe everything except internal storage if you want to go "back" to the next stable release of OOS 4.0 which I think will be released tomorrow
    btjayakody likes this.
  10. welberger
    Donut Dec 30, 2016
    welberger , Dec 30, 2016 :
    I did and had no problems so far. The only problem I had was when trying to use SuperSU this destroyed my connectivity. Oneplus was suddenly not able to detect my SIM card anymore. But a wipe and a new installation of the Beta did the trick.
  11. Deactivated User
    Dec 30, 2016
  12. Antoine Vdb
    KitKat Dec 30, 2016
    Antoine Vdb , Dec 30, 2016 :
    indeed the Nougat "double tap recents button to switch to last app" is way slower than before. Activating the OnePlus version of that feature isn't a solution
  13. namitlulla
    Cupcake Dec 30, 2016
  14. fjvaz1995
    fjvaz1995 , Dec 30, 2016 :
    Still facing the playstore issue of downloading stuck, any help would be appreciated.
    Did a factory reset and it did solve the problem,but it's arising again and again.
  15. Sun90
    Starting Point Expert Community Expert Dec 30, 2016
    Sun90 , Dec 30, 2016 :
    With the Hardware key Yes,
    But on navigation bar its fast
    Edit: if u set the animation scale to .5X in developer settings it will increase the speed a bit as I can see compared to 1x
    btjayakody and Zh_kilat like this.
  16. Kruemelfelix
  17. Kruemelfelix
    Turn Data or Battery Saver on. This is an Android problem. Oneplus can´t fix that
    fjvaz1995 likes this.
  18. Sun90
    Remove and restore app preferences for play store app and see
    Zh_kilat and fjvaz1995 like this.
  19. Alessandro95
    Alessandro95 , Dec 30, 2016 :
    No I'm not on beta
  20. fjvaz1995
    Nope ain't helping, and can u be more specific abt what the problem actually is?because it seems a silly issue to me.
