104
OxygenOS Open Beta 11 for the OnePlus 5 and Open Beta 9 for OnePlus 5T
  1. sachin_musician
    Gingerbread Jun 14, 2018
    sachin_musician , Jun 14, 2018 :
    Yes the Oil Painting effect is less now and the images look sharp, as the above image is cropped and taken in Portrait mode.
  2. G_T_Bennett
    Jelly Bean Jun 14, 2018
  3. Dhruv Weaver
    The Lab - OnePlus 7 Pro Reviewer Jun 14, 2018
    Dhruv Weaver , Jun 14, 2018 :
    They likely made an under-the-hood processing change. After all, the processing is the issue.
  4. P1520770731857
    Honeycomb Jun 14, 2018
    P1520770731857 , Jun 14, 2018 :
    Camera libraries have changed but they're still not proper. Dot pattern is still there on GCAM, when that is fixed we will have a proper working camera.
    yeffoll likes this.
  5. Dhruv Weaver
    I agree.
    the_reckoner and yeffoll like this.
  6. Nayanika Nagasree
    Froyo Jun 15, 2018
    Nayanika Nagasree , Jun 15, 2018 :
    Even after updating my camera version is 2.5.3 not even 2.5.33
    If I download and install the 2.5.33 from apkmirror it says installed but the camera version's same 2.5.3
    Can anyone help?
  7. Aswin08
    Honeycomb Jun 15, 2018
    Aswin08 , Jun 15, 2018 :
    Dot pattern in 3rd party cameras is a known issue. If you are using the fix for gcam, the dot pattern may look quite a bit reduced.
  8. Pochinki
    Froyo Jun 15, 2018
    Pochinki , Jun 15, 2018 :
    Flash the zip file again. I guess update didn't go through properly.
    Nayanika Nagasree likes this.
  9. The_Unkown
    Jelly Bean Jun 15, 2018
    The_Unkown , Jun 15, 2018 :
    Contrarily you sound ridiculous , any update in the software goes with the Change in the build number so as to leave a track record of the development done . I don't know of what background you are from , but if you would have been engineer you should appreciate that.
  10. Aswin08
    Nayanika Nagasree
    Can anyone help?
    You are using Camera M magisk mod? If so remove the module,reboot and install the latest from apkmirror.
  11. Aswin08
    What they are saying is there maybe zero changes in camera app, so why would they update the build number. The changes are only in library files.
  12. G_T_Bennett
    G_T_Bennett , Jun 15, 2018 :
    Complains for months about oil painting, receives change, complains for months that a digit isn't changed in the coding. What's more important?
  13. Deactivated User
    Jun 15, 2018
  14. The_Unkown
    do you really mean that they have changed nothing in the APK but they have directly put some code in processing unit to produce better result ?
  15. Sidharth Shrivastav
    Gingerbread Jun 15, 2018
  16. Sidharth Shrivastav
  17. Sidharth Shrivastav
    Sidharth Shrivastav , Jun 15, 2018 :
    happy to camera update thanks so much luv u one plus
