97
OxygenOS Open Beta 11 for the OnePlus 7 Pro and 7
  1. O1584799431674
    Eclair Mar 30, 2020
    balenax likes this.
  2. DMaarten
    Honeycomb Mar 30, 2020
    DMaarten , Mar 30, 2020 :
    You can use oxygen updater from the playstore to upgrade manually, of download it from one of the links i think i saw somewhere in this thread
  3. ssreenath.bhat
    Cupcake Mar 30, 2020
    ssreenath.bhat , Mar 30, 2020 :
    Hello,
    When will be getting the OTA stable update for One plus 7 and also the security patch for March. Please update.
  4. Gdsingh94
    Gdsingh94 , via OnePlus 7 , Mar 30, 2020 :
    its out already out... if you want it badly install oxygen updater and download it ..
  5. Q1577426540649
  6. imrantanvir
    Mohanoctane8 likes this.
  7. akks
    Jelly Bean Mar 30, 2020
    akks , Mar 30, 2020 :
    We?
  8. imrantanvir
  9. akks
  10. U1563787576368
  11. Koen1931
    Swejuggalo likes this.
  12. Swejuggalo
    KitKat Mar 30, 2020
    Swejuggalo , via OnePlus 7 Pro , Mar 30, 2020 :
    Tried any other warp charger or even any other slow charger (even USB port on computer) and then back on warp charger? No differance?
  13. Vgoswami66
    Cupcake Mar 31, 2020
  14. SHAAVEZ
    Froyo Mar 31, 2020
    SHAAVEZ , via OnePlus 7 Pro , Mar 31, 2020 :
    If anyone's Warp charge not working connect your phone to any Power bank (should be lower than 25W) and let it be connected for 2 minutes. Remove it and connect your phone back to your Warp charge. This simple thing will solve the problem.
  15. Venkatchandra
    Donut Mar 31, 2020
  16. X1568888095586
    Gingerbread Mar 31, 2020
    X1568888095586 , via OnePlus 7 Pro , Mar 31, 2020 :
    hlw I want to Know why my device OP 7pro didn't show WARP charging in display at the time of charging? but charging speed ok,it showed all time but suddenly did not showing WARP charging , why? what's the reason
  17. SHAAVEZ
    Froyo Mar 31, 2020
    X1568888095586
    hlw I want to Know why my device OP 7pro didn't show WARP charging in display at the time of charging? but charging speed ok,it showed all time but suddenly did not showing WARP charging , why? what's the reason​
    Hey! [e]1f60a[/e]
    Well what I observed it is a software issue (which I'm facing since the BETA 10) it might needs to detect the difference between the voltages or something I guess that is the reason this trick is working for many of the users after I suggested after I tried it myself.
  18. fahadleee
  19. X1568888095586
    Hey i confused what are you saying plz suggest me the way out so that Warp charging found in display when charging
