97
OxygenOS Open Beta 11 for the OnePlus 7 Pro and 7
  1. SHAAVEZ
    Froyo Mar 31, 2020
    SHAAVEZ , via OnePlus 7 Pro , Mar 31, 2020 :
    Ok let's start with the basics.
    How long does it takes for your phone to get charged? (With original brick and cable)
  2. Swejuggalo
    KitKat Mar 31, 2020
    Swejuggalo , via OnePlus 7 Pro , Mar 31, 2020 :
    As long as you have 10.3.1 you can go strait to beta 11 with no issues. No need of a previous beta version since the update file is a full update with everything included.
  3. fahadleee
    Gingerbread Mar 31, 2020
    fahadleee , via OnePlus 7 Pro , Mar 31, 2020 :
    Big thanks for your reply I really appreciate
    I will use beta cause beta has more features than stable
  4. gian_nyc
    Eclair Mar 31, 2020
    gian_nyc , Mar 31, 2020 :
    I noticed exactly the same thing, and I believe it is way more noticeable at in low light conditions. Also, I was wondering if it could be related to video enhancer feature in settings/display but I haven't done enough testing yet. It seems to happen less in newer betas (OB-10, OB-11) but perhaps I am not paying so much attention anymore.
  5. Swejuggalo
    KitKat Mar 31, 2020
    Exactly. More fun to use beta too 🙂
    fahadleee likes this.
  6. Mohsin720
    Cupcake Mar 31, 2020
  7. fahadleee
  8. fahadleee
  9. Swejuggalo
    KitKat Mar 31, 2020
    The bar is intended to disappear at the launcher but reappear when opening app. At the moment it's abit irregular. I've given them pretty detailed info on the behavior.
    It can hide in launcher but not show properly in apps while sometimes showing in both places.
  10. fahadleee
    thanks for your reply. hope it will be fixed in next update
  11. fahadleee
  12. Swejuggalo
    KitKat Mar 31, 2020
    If you are on beta you will continue to get beta unless leaving beta channel. Leaving beta can be done in 2 ways. Either flash a newer stable update manually over beta or use the rollback file to Pie. Both methods will wipe.
    Update/Downgrade your phone with starting from the community app. Downgrade file exists in the first post in OB1.
    https://forums.oneplus.com/threads/...-for-the-oneplus-7-and-oneplus-7-pro.1099154/. Video http://bit.ly/37ss8mI
    Downgrading will wipe to an International Pie firmware. OTA your way up if you want International. Flash EU build manually if you need EU.
    Various updates files are listed here.
    OnePlus[e]2122[/e]
    Everything OnePlus #NeverSettle
    Not endorsed by OnePlus
    https://t.me/OnePlus
    (open up with Telegram app)
  13. X1568888095586
  14. samardash
    Eclair Mar 31, 2020
  15. akks
    Jelly Bean Mar 31, 2020
    akks , Mar 31, 2020 :
    I just now moved back to stable build 10.3.2 from beta 11. Just flashed 10.3.2 zip file.. But data got wiped 😭
    Sai KrishnaD likes this.
  16. SHAAVEZ
    Froyo Mar 31, 2020
  17. Swejuggalo
    KitKat Mar 31, 2020
    Yeah. That sucks. Personally everything is synced and backed up. Passwords, 2 step verifications, pictures... Only need to install the apps. Not such a big fuss for me. Have some Oneplus Switch backup stored if I feel lazy though.
    There are cases were moving from beta to stable does not wipe. But I have never seen that happen personally on 7 series. Seen people flash on 6T with no wipes though...
  18. charmingash
    Honeycomb Mar 31, 2020
    charmingash , via OnePlus 7 , Mar 31, 2020 :
    pubg mobile is lagging heavly in 10.3.2 worst update than 10.3.1
    samardash likes this.
  19. samardash
    Eclair Mar 31, 2020
    samardash , via OnePlus 7 , Mar 31, 2020 :
    yah. whole frame drop. lag problem. heating issue. battery drain
    charmingash likes this.
  20. akks
    Yeah, my older OnePlus 3 it was possible without a wipe..
    Anyways had thought of a hard reset for quite a long time. Doing it for the first time after using my 7 Pro for almost a year now
