97
OxygenOS Open Beta 11 for the OnePlus 7 Pro and 7
  1. charmingash
    Honeycomb Mar 31, 2020
    charmingash , via OnePlus 7 , Mar 31, 2020 :
    i have downgraded to pie no frame drops smooth gameplay
    samardash likes this.
  2. FaxFoe
    Cupcake Mar 31, 2020
    FaxFoe , via OnePlus 7 , Mar 31, 2020 :
    Hi! I've noticed that the rotation suggestion button is missing when I rotate my phone (OP 7) in this Beta. Am I the only one? If not, can you please fix it? Thanks in advance!
  3. fahadleee
    Gingerbread Mar 31, 2020
    RandyManLB likes this.
  4. Rihan R
    Cupcake Apr 1, 2020
    Rihan R , via OnePlus 7 Pro , Apr 1, 2020 :
    Dear Team,
    Zip file download done total 2.33GB kindly tell me how to Install it step by step
    plz find above attachment & do the needful ASAP
    Regards,
    Rihan R
    [Personal information removed by moderator SoniaB]
  5. akks
    Jelly Bean Apr 1, 2020
    akks , Apr 1, 2020 :
    Firstly this is a beta build, flash it only if you are competent enough to handle probable bugs, also know how to report feedback properly. Read the opening post and also search for beta1 thread in the forum for details.
    And this is a community forum, not OnePlus support, Don't share your phone numbers and personal details here.
  6. samardash
    Eclair Apr 1, 2020
  7. fahadleee
    Gingerbread Apr 1, 2020
  8. X1568888095586
  9. FaxFoe
    Cupcake Apr 1, 2020
    FaxFoe , via OnePlus 7 , Apr 1, 2020 :
    Hello everyone!
    I've noticed that the rotation suggestion button is missing in this Beta. It doesn't appear when I rotate my phone. How do I fix this? Thanks in advance!
    Abeed7 likes this.
  10. Swejuggalo
    KitKat Apr 1, 2020
    Swejuggalo , via OnePlus 7 Pro , Apr 1, 2020 :
    Beta 12 or other navigation method I assume. Think it works with the normal button navigation. This issue is reported and replicated
  11. H1561035594205
    Eclair Apr 1, 2020
    H1561035594205 , via OnePlus 7 , Apr 1, 2020 :
  12. Jay2020
    Ice Cream Sandwich Apr 1, 2020
    Jay2020 , via OnePlus 7 Pro , Apr 1, 2020 :
    OB11, Is any one else having issues with all contacts not showing up in default and 3rd party text messaging app since OB11 update? All of my contacts are in my Contacts app, but some contacts are not pulling up when searched in text messaging app since OB11 update.
    Update:
    for whatever reason, this problem has worked itself out and is after 3 days no longer an issue.
    Sai KrishnaD likes this.
  13. Sai KrishnaD
  14. Lucazh
    Froyo Apr 1, 2020
  15. RohanShelar333 , via OnePlus 7 Pro , Apr 1, 2020 :
    create a thread for the same and share the logs as required to help OP assist the issue soon as possible
    The great dane and fahadleee like this.
  16. Swejuggalo
    KitKat Apr 1, 2020
    Report this via the feedback tool in the community app. They may return with extra instructions on how to catch logs.
    No apps that can control bluetooth? Does not happen for me
  17. Swejuggalo
    KitKat Apr 2, 2020
    Swejuggalo , via OnePlus 7 Pro , Apr 2, 2020 :
    How often does face unlock stop working? When it does check carefully for any extra info and reasons of why it does not. Even fingerprint may ask for password/pin after some time... It seems like Google made a change forcing the use of secondary unlocks even when using face unlock now.
  18. Jay2020
    Ice Cream Sandwich Apr 2, 2020
    Jay2020 , via OnePlus 7 Pro , Apr 2, 2020 :
    Ref:
    hi all, in the beta 11 my Bluetooth is turning on by itself. I don't know why. am I the only one?[/
    Reply:
    in OB11. There was s new system app added for Bluetooth called bttestmode. In OB11, my Firewall saw this trying to repeatedly access the internet in the background. I'm having no issues with Bluetooth while it's internet access blocked. Anyone know why Bttestmode needs internet access?
