350
OxygenOS Open Beta 12 (7.1.1) for OnePlus 3
  1. humanzqzr
    Honeycomb Mar 2, 2017
    humanzqzr , Mar 2, 2017 :
    Call recording feature should be enabled region wise where call recording is legal just like triple press power button dials emergency number in India.
  2. yofellas
    Gingerbread Mar 2, 2017
    yofellas , Mar 2, 2017 :
    heating issues with the new update.... also battery performance not impressive...
    Chendil likes this.
  3. yofellas
  4. Deactivated User
    Mar 2, 2017
  5. Dr.SamThomas
    Eclair Mar 2, 2017
    Dr.SamThomas , Mar 2, 2017 :
    @Tony L. Please look into the panorama..It's really messed up.. levelling and stitching are all messy and it's not something a flagship should do
  6. rarog
    Assistant Head Moderator Assistant Head Moderator Mar 2, 2017
    rarog , Mar 2, 2017 :
    I think they left it out due to missing translators. Though I know, that with the rules for Serbo-Croatian they could just make an autoconversion of the strings.
    Sun90 likes this.
  7. sammerasker
    Ice Cream Sandwich Mar 2, 2017
    sammerasker , Mar 2, 2017 :
    no, it works fine if disabled.
    Android450 likes this.
  8. dermot33
    dermot33 , Mar 2, 2017 :
    Yep.Its a mystery to me
  9. praveenshharma
    Eclair Mar 2, 2017
    praveenshharma , Mar 2, 2017 :
    can someone tell me how to join one plus beta program mode ? I'm new to one plus community..!!
  10. ThePrutser
    Froyo Mar 2, 2017
    ThePrutser , Mar 2, 2017 :
    Thanks for the suggestions.
    I have tried a couple a things:
    - reinstall ADB Fastboot
    - reinstall USB driver
    - renaming the .zip file
    - having the zip file in the ADB folder
    - having the zip file on a USB stick
    - running the ADB cmd prompt as Administrator
    - Updated Android SDK
    - redownloaded the .zip file
    - fiddled with the extension
    But it keeps telling me:
    * cannot read 'OnePlus3Oxygen_16_OTA_020_all_1702282144_9d1a3b0ffd694e79.zip' *
  11. ThePrutser
    Froyo Mar 2, 2017
    I found a very peculiar fix for this... I made adb.exe 'Large Address Aware' and it solved the problem.
    Ref:
    https://forum.xda-developers.com/showpost.php?p=69648733&postcount=47
    https://www.techpowerup.com/forums/threads/large-address-aware.112556/
    rarog likes this.
  12. Ankitbhat12345
    Jelly Bean Mar 2, 2017
    Ankitbhat12345 , Mar 2, 2017 :
    You can do local upgrade. If you are on 4.0.3 or ob11 you can do local upgrade. Just open.setting-system update-setting-local upgrade-choose ob12
  13. pieterytsma
    Donut Mar 2, 2017
    pieterytsma , Mar 2, 2017 :
    When i go to about phone, there is no recent information. My software is 7.1 instead of 7.1.1 and my patch is october in stead of march. Also there is no beta version information. What is the problem here? Thanks!
  14. sushil28
    Eclair Mar 2, 2017
  15. dermot33
    Your not on beta 12, take a screenshot of about phone
  16. pieterytsma
    Donut Mar 2, 2017
    Thanks for your help. Here are the screenshots. I am very sure i have flashed the beta 12, i also have the new galery features.
  17. aagamshah95
    Cupcake Mar 2, 2017
  18. F_Dennis_Schröder_kNSQ
    F_Dennis_Schröder_kNSQ , Mar 2, 2017 :
    Wipe cache for what? I made a clean flash with wipe everything. Don't think another wipe will make it better.
  19. Deactivated User
    Mar 2, 2017
  20. Alpha Mike Foxtrot
    KitKat Mar 2, 2017
    Alpha Mike Foxtrot , Mar 2, 2017 :
    Why are you flashing OnePlus software on a Pixel?o_O
    mrambriz, inkaine and ghostofcain like this.
