198
OxygenOS Open Beta 12 for the OnePlus 6 and Open Beta 4 for OnePlus 6T
  1. I1529945330724
    Cupcake Feb 11, 2019
    I1529945330724 , Feb 11, 2019 :
    exactly nor i can reply directly from the notification.
  2. gubro
    KitKat Feb 11, 2019
    gubro , Feb 11, 2019 :
    That's not right.
    I just tested, it works fine for me.
    Is it just WhatsApp or other applications as well?
    Are you using the beta version of WhatsApp by any chance?
  3. I1529945330724
    not only whatsap, bt others too. am using official watsap
    DaRaSWGM likes this.
  4. gubro
    KitKat Feb 11, 2019
    Well, you have 2 options:
    you can submit a bug report using the link in the first post, or you can try to do a factory reset (I have a feeling, that the bug hunters will ask you to do that anyway).
    As I could not replicate the issue, I think a factory reset will likely to sort it out.
    ironass likes this.
  5. I1529945330724
    hey, this is solved. actualy it was the swift instlr overlay issue. it had to be re instld after an OTA, wch i skipped. now its fine. thanku for ur time
  6. Jimmyostrom
    Gingerbread Feb 11, 2019
    Jimmyostrom , Feb 11, 2019 :
    what os do you have oxygen or hydrogen and du you use som 3:d party launcher? Because it doesn't look like the OnePlus launcher..
  7. I1529945330724
    its oxygen with nova launcher.
  8. gubro
    KitKat Feb 11, 2019
    Ah, mistery solved.
    Have a nice day!
    ironass likes this.
  9. I1529945330724
    ironass and gubro like this.
  10. G_Chhin_Raksmey_BPby
  11. marckok
    Froyo Feb 11, 2019
  12. stavros67
    Froyo Feb 11, 2019
  13. Raghav s
  14. Fauert
    Honeycomb Feb 11, 2019
  15. zoran81
    Jelly Bean Feb 11, 2019
  16. stavros67
    Froyo Feb 11, 2019
  17. ChristianHeilos
  18. MikeMp
    MikeMp , Feb 11, 2019 :
    So Beta 12 update is back! very difficult to see what has changed with this update. Screenshot perhaps.
    Thanks, any way.
  19. vriesdejoop
    Ice Cream Sandwich Feb 11, 2019
    vriesdejoop , Feb 11, 2019 :
    MikeMp
    Thanks, any way.
    nothing has changed, it's the same update as to weeks ago, the md5 check is exactly the same
    ironass likes this.
  20. Xankitx
    Eclair Feb 11, 2019
