196
OxygenOS Open Beta 12 for the OnePlus 6 and Open Beta 4 for OnePlus 6T
  1. G_Jonathan_Timm_vQZJ Donut Feb 12, 2019
  2. SpaZioMilano Gingerbread Feb 12, 2019
  3. Yannis Neris Ice Cream Sandwich Feb 12, 2019
  4. ButtKiss Eclair Feb 12, 2019
    ButtKiss, Feb 12, 2019 :
  5. ponlong22 Gingerbread Feb 12, 2019
  6. H1550000480461 Cupcake Feb 12, 2019
    H1550000480461, Feb 12, 2019 :
    I would like to participate and the oxygen OS open beta how do I install it and where do I locate the download
  7. ironass KitKat Feb 12, 2019
    ironass, Feb 12, 2019 :
    Read posts #1 & #3 of this thread, carefully and thoroughly.
    WARNING! Open Beta releases are for competent and experienced users since they may not always be stable and are for the purposes of testing and reporting to OnePlus to help them develop future stock firmware and features. By installing the Open Beta, you accept the potential risks. Once on the Open Beta pathway you will no longer receive the regular OnePlus, Official Stable OTA's and you will need to completely wipe your phone before attempting to return to Official Stable OnePlus stock firmware.
    Since the latest Open Beta updates for the OnePlus 6/6T have not been made available in the OnePlus download site, you will need to download the latest Open Beta from one of the private download links that are scattered throughout this thread and perform a Local upgrade. Grab a coffee and start reading.
    gubro likes this.
  8. ponlong22 Gingerbread Feb 12, 2019
    ponlong22, Feb 12, 2019 :
    go to the link provided on the thread, follow the instructions,
    welcome to ob
  9. bpwest80 KitKat Feb 12, 2019
    bpwest80, Feb 12, 2019 :
    I think I may have found a fix for my roaming problem on at&t. I went in the network settings and selected T-Mobile 4g as my network manually. I've never had to do that on any other phone. The phone usually selects your network automatically when you put the sim in. I didn't roam at all on the way home so hopefully I fixed it.
    rhyd1am, inkaine and ironass like this.
  10. ironass KitKat Feb 12, 2019
    Congratulations and fingers crossed that forcing a reconnection has worked bpwest80!
    I would never have guessed that as a solution. Thanks for posting your findings, so far. Let us know how it goes.
    bpwest80 likes this.
  11. bpwest80 KitKat Feb 13, 2019
    bpwest80, Feb 13, 2019 :
    I will. Like I said before, I've never had to go into network operater and select my network manually before. I would've tried it sooner but I forgot that setting was even there because I've always left it set to "automatically." But, if it'll fix my phone from connecting to at&t roaming on band 5 and getting stuck there, then I'll be happy. I was using Network Cell Info and on the way home it never even showed band 5. That's a good sign because the 3 XL didn't either.
  12. snabb Honeycomb Feb 13, 2019
    snabb, Feb 13, 2019 :
    You have right - no issue in safe mode. Then OnePlus needs to find out the solution to fix this issue.
    How did you find that it was exactly this app which was causing the issue?
  13. AdikartaDasa Gingerbread Feb 13, 2019
    AdikartaDasa, Feb 13, 2019 :
    Can't find the new ob4 link anywhere in the thread.
    Please share.
  14. bpwest80 KitKat Feb 13, 2019
    Try the app Oxygen Updater from the Play Store
    AdikartaDasa likes this.
  15. AdikartaDasa Gingerbread Feb 13, 2019
    I'm in the old ob4. Oxygen updater is not showing new ob4...
  16. rudro_sett Froyo Feb 13, 2019
    rudro_sett, Feb 13, 2019 :
    is this update safe now? It got recalled originally because it made devices not boot
  17. bpwest80 KitKat Feb 13, 2019
    The old OB4 is the new OB4. They're the exact same build.
    ironass likes this.
  18. AdikartaDasa Gingerbread Feb 13, 2019
    Oh dam.
    My bad. Thanks for your time.
  19. bpwest80 KitKat Feb 13, 2019
    No problem.
  20. vjayy7684 Eclair Feb 13, 2019
    vjayy7684, Feb 13, 2019 :
    after factory reset again in 2 days this problem started again am feeling I made big mistake buy getting OnePlus device this will be my last OnePlus device
