196
OxygenOS Open Beta 12 for the OnePlus 6 and Open Beta 4 for OnePlus 6T
  1. bpwest80 KitKat Feb 13, 2019
    bpwest80, Feb 13, 2019 :
    What does Google Play Services have to do with the 6t? If it's draining battery is because of Play Services not the 6t.
  2. dragonfan Eclair Feb 13, 2019
    dragonfan, Feb 13, 2019 :
    so i am still on the Beta 11 and everytime i go to system updated it only says "checking updates" endlessly. any help on how to resolve the issue and return to having the normal betas OTA updates?
  3. ironass KitKat Feb 13, 2019
    ironass, Feb 13, 2019 :
    Download Oxygen Updater, free from the Play Store.
    AdikartaDasa likes this.
  4. G_gaganpreet_singh Gingerbread Feb 13, 2019
  5. B_Wrath Marshmallow Feb 13, 2019
    B_Wrath, Feb 13, 2019 :
    It works only for whatsapp and insta at the moment, as far as I know.
  6. G_gaganpreet_singh Gingerbread Feb 13, 2019
    G_gaganpreet_singh, Feb 13, 2019 :
    will it work for the moded version of WhatsApp (YoWhatsapp)?
  7. B_Wrath Marshmallow Feb 13, 2019
    No it won't.
    G_gaganpreet_singh likes this.
  8. G_gaganpreet_singh Gingerbread Feb 13, 2019
  9. B_Wrath Marshmallow Feb 13, 2019
    Don't use modded version of chat apps if you care about privacy.
    AdikartaDasa and Kytharsis like this.
  10. G_gaganpreet_singh Gingerbread Feb 13, 2019
    nothing to care about in my chats bro [e]1f60a[/e]
    btw thanks for the suggestion
  11. Lauantai Gingerbread Feb 13, 2019
    Lauantai, Feb 13, 2019 :
    anyone else experiencing this.
    screen unlocked, put your phone on table and it will make a notification sound. just started... screen does not go locked or nothing shows up. just the sound.
  12. Yannis Neris Ice Cream Sandwich Feb 13, 2019
    Yannis Neris, Feb 13, 2019 :
    Play services drain is a pain in the ***
    Don't blame Oneplus for this .
    Blame Google
    One of your apps and your setup is responsible
    rhyd1am, Kytharsis and ironass like this.
  13. Frederickc Honeycomb Feb 13, 2019
    Frederickc, Feb 13, 2019 :
    Hi Guys,
    I've encountered an issue with my phone (6T Mclaren).
    Since I've updated tot Beta_04 I noticed my phone doesn't notificate that he is Warp Charging or normal Charging. It doesn't matter via which charger I charge, the icon stays the same.
    Is anybody else having this same issue?
    alisaman124 likes this.
  14. ironass KitKat Feb 13, 2019
    See post #3 of this thread.
    Frederickc likes this.
  15. vjayy7684 Eclair Feb 13, 2019
    vjayy7684, Feb 13, 2019 :
    why only OnePlus device have Google Play service battery drain issue not with other company cells have this issue
  16. vjayy7684 Eclair Feb 13, 2019
    am using Samsung also with same apps why Samsung mobile don't have Google Play service battery drain issue
  17. bpwest80 KitKat Feb 13, 2019
    They don't. I've had play services drain problems before on different phones. Pixel XL, 6p and my 2 XL all had drain problems with play services at some point. I usually fixed it myself but one time I had to wait until it was updated. And sometimes it may not even be play services that's draining your battery. It may just be a bad app making play services run more. I usually tracked down the problem with Gsam Battery Monitor. You'll have to use ADB if you want the stats you'll need to track down the problem. It's not the phone I guarantee you.
    ironass likes this.
  18. bpwest80 KitKat Feb 13, 2019
    Registering my 6t on T-Mobile 4g network manually fixed my roaming issue. I still don't think you should have to do that though. The phone should know what network to select automatically, like every other phone I've ever owned. I've never had to manually select my network before. Anyways, no more band 5 roaming.
    ironass likes this.
  19. ironass KitKat Feb 13, 2019
    Great news bpwest80! I am so pleased that you tracked down a fix. :)
    bpwest80 likes this.
  20. bpwest80 KitKat Feb 13, 2019
    Yeah me too. I usually can track it down because I don't quit. Lol
    I still think it should be looked into because I've never had to manually select my network before in order for my phone to work correctly. The reason I didn't think to try it earlier was because I had forgotten about that setting.
    ironass likes this.
