538
OxygenOS Open Beta 13 for the OnePlus 5 and Open Beta 11 for OnePlus 5T
  1. Artemus.
    Nougat Jul 6, 2018
    Artemus. , Jul 6, 2018 :
    Did you flash it from stable?
  2. Drsakthibalan
    Cupcake Jul 6, 2018
  3. Drsakthibalan
    Cupcake Jul 6, 2018
    Drsakthibalan , Jul 6, 2018 :
    did any one experience this?
  4. G_T_Bennett
    Jelly Bean Jul 6, 2018
    G_T_Bennett , Jul 6, 2018 :
    You're saying of course like this is the right thing to do. (which it isn't) No wonder why you lost your data.
    CHETHANGV2, Themurtuza and alogim like this.
  5. DigiPimp
    Eclair Jul 6, 2018
    DigiPimp , Jul 6, 2018 :
    no matter how many cache deletes and app reinstalls the capital one app won't work
    deviantartjr and Drsakthibalan like this.
  6. Drsakthibalan
    Cupcake Jul 6, 2018
    G_T_Bennett
    You're saying of course like this is the right thing to do. (which it isn't) No wonder why you lost your data.​
    as usual I downloaded new updated, on booting the mobile became unstable, it showed " system UI error". went to reboot mode. and never got my previous screen or datas, had to take to service center today. they flashed to older stable version. told me not to download beta version again. data lost because the service person told there is only one option, that is to flash OS, so all data can't be regained
    CHETHANGV2 likes this.
  7. G_T_Bennett
    Follow their advice. Sorry for the loss of your data.
  8. alogim
    Ice Cream Sandwich Jul 6, 2018
    alogim , Jul 6, 2018 :
    Then you can't read. In the post, it clearly states the following:
    Note: As this build supports Project Treble, if you are not running Open Beta 12 for OnePlus 5 and Open Beta 10 for OnePlus 5T, make sure you flash the builds before updating. If not, you should clear all data and cache from recovery before flashing the latest build.
    No wonder they told you not to flash beta builds anymore, you clearly haven't the necessary (basic) knowledge.
    CHETHANGV2 and Themurtuza like this.
  9. alogim
    There is no advanced reboot in that build. Hopefully, they will restore it in the future builds. However, remember it is a beta for a reason.
    I think this is the first proper beta, with actual bugs which need to be reported.
  10. Mephisto02
    KitKat Jul 7, 2018
    Mephisto02 , Jul 7, 2018 :
    yes battery life is bad for me too ,
    CHETHANGV2 and Brock Burkett like this.
  11. fecfecfec
    Donut Jul 7, 2018
    fecfecfec , Jul 7, 2018 :
    I tried this first and it didn't work.
    Updating to previous beta worked and then I updated through OTA.
  12. Tanaous
    Cupcake Jul 7, 2018
    Tanaous , Jul 7, 2018 :
    my op5t had ota update from ob10,but "Network debugging" disappeared in debug mode,how to fix it?
  13. cbbella
    Cupcake Jul 7, 2018
    cbbella , Jul 7, 2018 :
    i have op5t and updated to open beta 11 using funk wizards method so I don't lose any data and I don't have to reinstall everything. I have used his method for all previous beta updates but with this beta 11 the advanced reboot menu has disappeared and it's not showing in developer options.
    anyone else had this problem
  14. devanandpawar
    Cupcake Jul 7, 2018
  15. devanandpawar
    Cupcake Jul 7, 2018
  16. I1530254299940
    Eclair Jul 7, 2018
    I1530254299940 , Jul 7, 2018 :
    yes. even with clean install, I'm not able to see advance reboot in developer settings.
    CHETHANGV2 and cbbella like this.
  17. Waveform Modifier
    Marshmallow Jul 7, 2018
    Waveform Modifier , Jul 7, 2018 :
    Turned on Smart lock by accident?
    Also. Beta related inquiry, comments and complaints goes to pinned beta thread.
    the_o2 likes this.
  18. I1530254299940
    Eclair Jul 7, 2018
    when you install the update? it will take 3 full recharge cycle to get a stable battery life.
  19. Waveform Modifier
    the_o2 likes this.
  20. cbbella
    Cupcake Jul 7, 2018
    hold volume down and power key to get into twrp recovery
