81
OxygenOS Open Beta 13 for the OnePlus 6 and Open Beta 5 for OnePlus 6T
  1. vigneshmiller
    Gingerbread Feb 28, 2019
    vigneshmiller , Feb 28, 2019 :
    Yep I feel the same while I was reading those comments [e]1f602[/e].
    zoran81 and ronnyhawks like this.
  2. B_Wrath
    Marshmallow Feb 28, 2019
    B_Wrath , Feb 28, 2019 :
    @Manu J. Can you explain why the Amazon prime app was included in this build for the Indian users? I per se won't have any problem with it, but this thread is being flooded with that question. Your explanation will be much appreciated.
    @camohan can you help in getting this clarified? I don't know if Manu will see and respond my post.
    TheAyushJain and zoran81 like this.
  3. L1535192385424
    Cupcake Feb 28, 2019
  4. PrakarshX
    Honeycomb Feb 28, 2019
    PrakarshX , Feb 28, 2019 :
    how can I say no to that face?
  5. Sankalp_fs
    Froyo Feb 28, 2019
    Sankalp_fs , Feb 28, 2019 :
    same here
  6. RobinNet
    RobinNet , Feb 28, 2019 :
    Why you don't have option to downgrade from openbeta to stable version? No offense, this is an abuse.
    I tried many solution, nothing works.
  7. Deactivated User
    Feb 28, 2019
    Deactivated User , Feb 28, 2019 :
    A quick search gives you a solution. Look at XDA.
    ronnyhawks likes this.
  8. gubro
    KitKat Feb 28, 2019
    gubro , Feb 28, 2019 :
    Abuse?
    Well, searching the forum is something a beta tester should be able to do.
    It is all there.
    B_Wrath, ronnyhawks and Huigiebaby like this.
  9. RobinNet
  10. ronnyhawks
    Ice Cream Sandwich Feb 28, 2019
    ronnyhawks , Feb 28, 2019 :
    no Captain Jack@ss. I said clean the camera lens off before taking a picture. you sound completely retarded. like you didn't completely understand what I said. OnePlus camera takes clear as day pics. better than 99% of phones on the market. not good enough for you? buy a DSLR then [e]1f44d[/e] problem solved
    zoran81 likes this.
  11. ronnyhawks
    no issues here for me
  12. Yannis Neris
    Yannis Neris , Feb 28, 2019 :
    If you have twrp ,you can just dirty flash 9.0.12 on top of beta 5
    I dont know if it works on stock recovery
  13. massek
    Froyo Feb 28, 2019
    massek , Feb 28, 2019 :
    I have op6 without twrp. A made clean install 3 times with full wipe and it isn't solve problem... I have no idea what to do.
  14. S1527013641491
  15. viva_la_tko
    viva_la_tko , Feb 28, 2019 :
    Well I hope it will be in open beta 14
    S1527013641491 likes this.
  16. MikeMp
    MikeMp , Feb 28, 2019 :
    You don't seem to know what you are talking about.
    1. I complained about picture quality.
    2. You advised me that there is no problem with the stock camera. And that i have to clean the lens to remove dirt, suggesting that my problem is from the lens.
    3. I told you i use Gcam and pictures come out very good. this was to mean that there is no problem with my lens, because Gcam uses the same lens.
    Or perhaps you have problems with English. You can be excused for your misunderstanding if that's the case.
  17. gubro
    KitKat Feb 28, 2019
    You will get it in Android Q.
    drl431 and PrakarshX like this.
  18. gubro
    KitKat Feb 28, 2019
    I hope it will be not.
  19. viva_la_tko
  20. L1539532583564
    L1539532583564 , Feb 28, 2019 :
    yes ,
