159
OxygenOS Open Beta 14 for the OnePlus 6 and Open Beta 6 for OnePlus 6T
  1. B1552556095394 Cupcake Mar 14, 2019
  2. ngydat KitKat Mar 14, 2019
    ngydat, Mar 14, 2019 :
    Yes there are instructions to go back to the stable OTA
  3. B1552556095394 Cupcake Mar 14, 2019
  4. vikku1993 Donut Mar 14, 2019
    vikku1993, Mar 14, 2019 :
    post #3
  5. ngydat KitKat Mar 14, 2019
  6. V1528092596981 Cupcake Mar 14, 2019
  7. B_Wrath Lollipop Mar 14, 2019
    B_Wrath, Mar 14, 2019 :
    Did you even read the opening post of this thread?
  8. BhavyaMehta0786 Honeycomb Mar 14, 2019
    BhavyaMehta0786, Mar 14, 2019 :
    Sadly yeah, but this is way better than the normal method of having to flash the twrp using ADB each time a new update rolls out and then flashing magisk using twrp.
  9. BhavyaMehta0786 Honeycomb Mar 14, 2019
    you must have somehow disabled the background data in the app setting which prevents apps from using data when they are running in the background.
  10. anurag.khurana03 Donut Mar 14, 2019
  11. vikku1993 Donut Mar 14, 2019
    it will be fixed in new update
    anurag.khurana03 likes this.
  12. Maddy00797 Cupcake Mar 14, 2019
    Maddy00797, Mar 14, 2019 :
    Hi Developer,
    Dual Volte support not working after this update so please check and fix it asap.
  13. anurag.khurana03 Donut Mar 14, 2019
  14. Maddy00797 Cupcake Mar 14, 2019
    did thrice time not working
  15. Maddy00797 Cupcake Mar 14, 2019
    till the time?? how can I servive?
  16. drl431 Jelly Bean Mar 14, 2019
    drl431, Mar 14, 2019 :
    No offence, but why are you beta testing new software?
    ironass likes this.
  17. PatrickNL Froyo Mar 14, 2019
    PatrickNL, Mar 14, 2019 :
    Good stable release so far, also battery consumption is better then current stable version
  18. vikku1993 Donut Mar 14, 2019
    you can submit a bug report
  19. Maddy00797 Cupcake Mar 14, 2019
  20. Saenz4931 Gingerbread Mar 14, 2019
    Saenz4931, Mar 14, 2019 :
    it's anyone having issues with Pandora?.. I am having problems since Beta 13 and now 14. the music is kept playing in the background, while the app become unresponsive completely. play, Skip, well the whole app is completely frozen. the only thing that works is to reply the song, which it does on top of the song that is playing. the only way to stop it is to force stop the application.. already cleaned phone cache.. Pandora's cache, data, install and reinstall the app.
