116
OxygenOS Open Beta 15 for the OnePlus 5 and Open Beta 13 for OnePlus 5T
  1. G_T_Bennett
    Jelly Bean Aug 4, 2018
  2. caillou0201
    Froyo Aug 4, 2018
    caillou0201 , Aug 4, 2018 :
    OnePlus garranty this kind of things do go ahead, everything is explain [e]1f60c[/e]
  3. Mr_Cyrox
    KitKat Aug 4, 2018
    Mr_Cyrox , Aug 4, 2018 :
    Well i do not like this mention
    It used to be that you dont lose data going from stable to beta...
    Is it after tremble support?
    caillou0201 likes this.
  4. iRohitPandey
    Donut Aug 4, 2018
    G_T_Bennett likes this.
  5. caillou0201
    Froyo Aug 4, 2018
    you have to wipe everything of you go to beta
  6. Mr_Cyrox
    KitKat Aug 4, 2018
    Then I'm not going to beta...
    Maybe in a few months when I factory reset my phone...
  7. caillou0201
    Froyo Aug 4, 2018
    you can do this :) if you want any help I'm on the beta and it's easy
  8. Mr_Cyrox
    KitKat Aug 4, 2018
    data loss is what I'm concerned about...
  9. G_Akshay_TR_cVba
    Cupcake Aug 4, 2018
    G_Akshay_TR_cVba , Aug 4, 2018 :
    I can't switch data card from menu bar, I have to go to settings every now and then to change data card.
  10. caillou0201
    Froyo Aug 4, 2018
    do a OnePlus switch backup ?
  11. G_T_Bennett
    G_T_Bennett , Aug 4, 2018 :
    Data can be very easily backed up.
  12. Mr_Cyrox
    KitKat Aug 4, 2018
    yeah i get that but its annoying as you can't back up settings of apps and system settings...
  13. caillou0201
    Froyo Aug 4, 2018
    ahaha but why are you in this forum if you really really don't want to just do a backup/ wipe/ upgrade/ restore and connect with your identifiant on each app. everything in 30 min will be done !
    Rambo15 and Mr_Cyrox like this.
  14. Mr_Cyrox
    KitKat Aug 4, 2018
    most of the time I forget what i need to backup...
    when i do a backup i always forget same files like music and etc...
    In other words I'm bad at backups XD
  15. caillou0201
    Froyo Aug 4, 2018
    with OnePlus switch you can backup easely! just choose what kind of document and data you need
  16. Mr_Cyrox
    KitKat Aug 4, 2018
    Last time i tried OnePlus Switch before even starting a backup the app crashed (all the time)
  17. caillou0201
    Froyo Aug 4, 2018
    this app has been upgrade and now it's stable and completely working
  18. Mr_Cyrox
    KitKat Aug 4, 2018
    Ok will give it a second chance
  19. caillou0201
    Froyo Aug 4, 2018
    Mr_Cyrox likes this.
  20. Mr_Cyrox
    KitKat Aug 4, 2018
    so to go to open beta i need to do a factory reset, download the open beta 15 .zip file, flash it and clear cache and thats it?
    or do i still need to flash the old tremble supported Open Beta first and update using OTA?
