116
OxygenOS Open Beta 15 for the OnePlus 5 and Open Beta 13 for OnePlus 5T
  1. Mr_Cyrox
    KitKat Aug 5, 2018
    Mr_Cyrox , Aug 5, 2018 :
    Open Beta 12 doesn't delete user data right?
    so i just flash that and see...
    and yeah i knew the risks of open beta before.
  2. Jobmakers
    Cupcake Aug 5, 2018
  3. G_T_Bennett
    Jelly Bean Aug 5, 2018
    G_T_Bennett , Aug 5, 2018 :
    Then use Stable. You have the option. This is a useless complaint.
  4. maheshgb
    Eclair Aug 5, 2018
    maheshgb , Aug 5, 2018 :
    thanks for reading. Complaint or suggestion, you are not the one to resolve. This forum is for expressing opinions. No point judging it. But if that's your way of expressing, good luck!!
  5. MJ_Vikram
    KitKat Aug 5, 2018
    MJ_Vikram , Aug 5, 2018 :
    you have downloaded and flashed beta so you are getting beta updates..
    once you do that you won't get stable update..
  6. sanjukozhummal
    Donut Aug 5, 2018
  7. Paul013
    Honeycomb Aug 5, 2018
    Paul013 , Aug 5, 2018 :
    Agreed.
  8. danvxz
  9. PokiX
  10. Mr_Cyrox
    KitKat Aug 5, 2018
  11. Mr_Cyrox
    KitKat Aug 5, 2018
    Ayy that was simple enough...
    Just factory reset and flash the beta XD
    Love the New UI and RGB Accent Colors XD
  12. E.D.T.H
    Eclair Aug 5, 2018
  13. PokiX
    PokiX , Aug 5, 2018 :
    with the beta? ..
  14. E.D.T.H
    Eclair Aug 5, 2018
  15. Mr_Cyrox
    KitKat Aug 5, 2018
    Why would you use gfx tools on a high end phone?
    To reduce "overheating"?
  16. nitrek
    Gingerbread Aug 5, 2018
    nitrek , Aug 5, 2018 :
    Bug on caller screen after update
    I am on open beta 13 and getting this bug after recent update
    the button on caller screen are shifted to left
    anyone else also facing this issue ?
  17. E.D.T.H
    Eclair Aug 5, 2018
    E.D.T.H , Aug 5, 2018 :
    To get more frames... And 16:9 screen ratio
  18. MJ_Vikram
    KitKat Aug 5, 2018
    Screen Shot is visible ..
  19. nitrek
  20. Mr_Cyrox
    KitKat Aug 5, 2018
    on my OnePlus 5 i don't need to do anything and i play at 60 fps, Full HD, High graphics setting
