152
OxygenOS Open Beta 15 for the OnePlus 6 and Open Beta 7 for OnePlus 6T
  1. Saenz4931
    Honeycomb Mar 29, 2019
    Saenz4931 , Mar 29, 2019 :
    dudo mucho lo hayas hecho por equivocacion, pero ya es parte de tu problema. cómo te an mencionado anteriormente. Lee el post 3 y sigue las indicaciones. o mejor, busca en Youtube el tutoría de cómo usar msmtool para regresar al estado estable. lo otro es buscar ayuda en los foros de español en esta misma página. o para mejor en la página web de xda developer bajo OnePlus 6T guides
    https://forum.xda-developers.com/oneplus-6t/how-to/tool-6t-msmdownloadtool-v4-0-oos-9-0-5-t3867448
  2. dronedoom
    Gingerbread Mar 29, 2019
  3. Adex0ne
    Ice Cream Sandwich Mar 29, 2019
  4. Shaji06
    Froyo Mar 29, 2019
  5. dronedoom
    dronedoom , Mar 29, 2019 :
    If you can't verify in intune then there's nothing to say really
  6. loknathmylaru
    Cupcake Mar 29, 2019
  7. Adex0ne
  8. loknathmylaru
  9. Saenz4931
    zoran81 likes this.
  10. NathanRoche
    Froyo Mar 29, 2019
  11. loknathmylaru
    loknathmylaru , Mar 29, 2019 :
    no......
  12. B_Wrath
    Marshmallow Mar 29, 2019
    B_Wrath , Mar 29, 2019 :
    I don't have any battery drain problem. Don't mislead people.
  13. B_Wrath
    I don't even think that he knows what kkk means.
    Kytharsis likes this.
  14. NathanRoche
    Froyo Mar 29, 2019
    NathanRoche , Mar 29, 2019 :
    I've had battery drain problems since the updates and people like you mislead not me.This phone is way expensive and I expect a decent battery life which I don't get on the 9.0.4
  15. Saenz4931
    LOL. I know,.. just thought it is funny what a spelling my seen different for others.
    B_Wrath likes this.
  16. B_Wrath
    Then go discuss in 9.0.4 thread or read the pinned battery thread. This is a beta thread.
    Battery drain is mostly user induced. Know what is causing your drain and fix it. Unless it is "Android OS" which is causing the drain, it is a problem you caused.
    zoran81, Loper_fan and ironass like this.
  17. NathanRoche
    Froyo Mar 29, 2019
    have u even read what I have posted.Youre dum.Understand that I asked if the battery issue is solved.And people like you are hiding/deleting posts of all the users to that are going though the same situation and not some they're a lot of people.
  18. B_Wrath
    I think you are dumb. I didn't even quote you on the misleading comment. It was some other guy. You tried to show off.
    I'll now stop this discussion and let's not go any more off topic.
  19. JAGADISH BHATTA
    JAGADISH BHATTA , Mar 29, 2019 :
    Its google not one plus android UI has not been changed much from android 6.0 and this material design is becoming boring
    Chungtd likes this.
  20. JAGADISH BHATTA
    Stable updates are delivered once in two months by one plus
