153
OxygenOS Open Beta 15 for the OnePlus 6 and Open Beta 7 for OnePlus 6T
  1. Bandhiya bhimashee
    Cupcake Mar 26, 2019
    #81
  2. Mandeepd111
    Mandeepd111 , Mar 26, 2019 :
    sometimes the while incoming call, the screen is not lighting up what might be the problem? pleade update it in the next beta release
    #82
    AntiHero7 and robin143 like this.
  3. gvamsi_krishna
    Gingerbread Mar 26, 2019
    gvamsi_krishna , Mar 26, 2019 :
    It's Borderlight app for border lighting effect and added wallpaper in it with changed visibility setting.
    Here's the wallpaper:
    #83
    G1541777717518 likes this.
  4. G_Deepak_Kumar_OAAf
    #84
  5. oneplustwoindia
    Froyo Mar 26, 2019
    oneplustwoindia , Mar 26, 2019 :
    Can you update these pinned posts with all the known major bugs which gets reported once users upgrades with new releases so that it would help the users to make a calculative move wether they want to update or not? @Manu J.
    #85
    javier87 likes this.
  6. G_Deepak_Kumar_OAAf
    G_Deepak_Kumar_OAAf , Mar 26, 2019 :
    from where I can update this one
    #86
  7. oneplustwoindia
    Froyo Mar 26, 2019
    Seems you're on stable version.
    If you want these updates you need to migrate to beta
    #87
  8. owngaurav
    Froyo Mar 26, 2019
    #88
  9. eliamarisio
    eliamarisio , Mar 26, 2019 :
    gvamsi_krish
    1. More & easily accessable options for screenshot & photo editing.
    2. New phone UI with bottom bar.
    How do you got the lights all over the borders of the phone?
    #89
    rajeev1989abc likes this.
  10. aakashmaji16
    aakashmaji16 , Mar 26, 2019 :
    If this feature is available on google dailer than Google's screen call will come to Oneplus Dailer with near about 2020
    #90
    iamkrafi likes this.
  11. gvamsi_krishna
    Use Borderlight app from Playstore and you can adjust settings in it.
    #91
  12. Adex0ne
    Ice Cream Sandwich Mar 26, 2019
    Adex0ne , Mar 26, 2019 :
    Google screen call? would Google release that feature to other Android phone makers?
    All I want is a Google stock dialer which can be used across PC and will soon have that chatting feature like apple
    #92
    aakashmaji16 likes this.
  13. O.Montero
    #93
  14. Adex0ne
    Are you on a fake version? what precisely ,be specific
    #94
  15. O.Montero
    O.Montero , Mar 26, 2019 :
    I need to go back to the official version, I'm in beta 7.
    #95
  16. aakashmaji16
    Also Oneplus should allow users to install Google dailer directly from playstore. I really like the Google dailer UI
    #96
  17. Adex0ne
    do you have the full ROM, if yes, then it's same procedure as beta
    #97
  18. N1539961316860
    Froyo Mar 26, 2019
    N1539961316860 , Mar 26, 2019 :
    can we expect brightness issue fix in this coming stable update?
    #98
  19. Adex0ne
    You can get it on apkmirror
    #99
  20. aakashmaji16
    apkmirror versions are buggy and patched versions to which they sometimes break functionality while taking calls
