198
OxygenOS Open Beta 16/7 for the OnePlus 3/3T
Thread Status:
Not open for further replies.
  1. Dunnow
    The Lab - OnePlus 6 Reviewer May 16, 2017
    Dunnow , May 16, 2017 :
    HEY THANK YOU SO MUCH FOR THIS AMAZING UPDATE ONEPLUS IMMA USE IT RIGHT AWAY
  2. kromus98
    Gingerbread May 16, 2017
    kromus98 , May 16, 2017 :
    by all after flashing the full zip whit twrp I am facing this issue and the ambient display is not working properly, because when the screen woke up from a notification I am not able to interact whit notification until I press the power buttons. what should I do ?
    ps. during the installation my recovery wasn't replaced from the official and that's strange
  3. Adam Krisko
    NA Community Consultant Staff Member May 16, 2017
    otto2, jpts, asasione and 8 others like this.
  4. anandbibek
    anandbibek , May 16, 2017 :
    Font sizes were f*ed up in last update. This update further f*s up the font weights (bold, thin, light). Google designed the fonts and size guidelines for a purpose. Don't mess with it just coz you have to change something for the sake of it. This is ridiculous.
    abiks192 likes this.
  5. Sun90
    Starting Point Expert Community Expert May 16, 2017
    Sun90 , May 16, 2017 :
    Sure.thanks.
  6. Sun90
    They are trying to fix some minor errors.
    So after some time pls re-download and flash again and see.
    otto2 and Bobbie63 like this.
  7. raajpradheep
  8. chirantanad
    Honeycomb May 16, 2017
    SgtRolf and [email protected] like this.
  9. kalander Shihab
    Jelly Bean May 16, 2017
    kalander Shihab , May 16, 2017 :
    Apps that support dual apps drain away all my battery
    It doesn't even let the kernel go to deep sleep lol. I have to manually force close these apps
  10. Android450
    Marshmallow May 16, 2017
    Android450 , May 16, 2017 :
    And what makes you think anything they do will be any different? It's just bloat
    otto2, ssagheer, Bobbie63 and 2 others like this.
  11. Android450
    otto2, ssagheer, Sun90 and 2 others like this.
  12. Sun90
    Got anything better to do.:eek:
    otto2, ssagheer, Dresa91 and 2 others like this.
  13. Playa82
    Eclair May 16, 2017
    Playa82 , May 16, 2017 :
    is there a way to change the way to answer a call ? it's better to do it like in pixel phones (swipe up to answer a call)
    G_Ovi_-_tZFm likes this.
  14. wenna
    Ice Cream Sandwich May 16, 2017
    wenna , May 16, 2017 :
    Is this also for OB7? (Did not see it mentioned in that thread)
    If so could you share the new md5 hash for OB7 as I've just finished downloading it and want to know if I have the correct file.
    Sun90 likes this.
  15. Sun90
    If there was one then you would have seen an announcement of the same in op2 section for now.
    otto2, Bobbie63, ssagheer and 2 others like this.
  16. Android450
    Bobbie63, Sun90 and adpro like this.
  17. rameez0307
    rameez0307 , May 16, 2017 :
    where is the official OTA update..again a beta update..are you stacking all the beta update for apocalypse..this is ridiculous
  18. Sun90
    You can Install the modified pixel dialer from XDA for it.
  19. Android450
  20. rameez0307
    they are just waiting for the oneplus 5 launch..they are fine tuning all the software to be used in oneplus 5 and guess what oneplus 3/3T users are the guinea pigs for all the best experiment..I can bet they will release OTA for OnePlus 3/3T after the OnePlus 5 launch..(*I have inside information)..that's why I am pissed off..OnePlus is very week in software department..
    [email protected] likes this.
