75
OxygenOS Open Beta 16 for the OnePlus 7 Pro and 7
What do u think?
  1. On purpose
    1 vote(s)
    100.0%
  2. This is a bug
    0 vote(s)
    0.0%
  3. IDK just want check answers
    0 vote(s)
    0.0%
  1. D1575113132678
    Cupcake Jul 12, 2020
  2. Fmps1987
    Honeycomb Jul 12, 2020
    tarun17 likes this.
  3. Shadow0929
    Jelly Bean Jul 12, 2020
  4. danial.aw
    Eclair Jul 13, 2020
    danial.aw , via OnePlus 7 Pro , Jul 13, 2020 :
    Want to report that the UI pixelation issue on certain apps is still not fixed.
    This can be seen in i.e. Facebook Messenger if you notice the icons in the bottom bar they are pixelated and not sharp as they should be. This issue has only popped up in the last few betas.
  5. ManuWill , via OnePlus 7 Mirror Gray , Jul 13, 2020 :
    You should've received tons of updates after pie, if you can't see an update in settings , manually update to pie in an incremental fashion
  6. prasad321
    Gingerbread Jul 13, 2020
    prasad321 , via OnePlus 7 , Jul 13, 2020 :
    Yes. Open beta 15 and 16 don't have any issue with portrait photography. But stable has it in 10.3.3. You can wait for next stable release which will be released in next month.
  7. prasad321
    HZ_ND likes this.
  8. Mr.Sgm
    Cupcake Jul 13, 2020
    Mr.Sgm , Jul 13, 2020 :
    how to download open beta 16 (Indian Version) please guide
  9. The Mastermind
    Froyo Jul 13, 2020
  10. prasad321
    Pros.
    1. You can use upcoming features on open beta which are suppose to come to stable in 2-4 months time.
    2. Bugs in stable are fixed immediately in beta
    3. I didn't experienced heavy battery drain on my 7 after moving to open beta
    Cons.
    1. There maybe a possibility of bugs in upcoming features
    2. Possibility of breking working features (possibility is less)
    3. Major bugs(possibility is less)
  11. HZ_ND
    HZ_ND , via OnePlus 7 Pro , Jul 13, 2020 :
    Will try that tonight.
  12. prasad321
  13. prasad321
    Its fixed bro. Not experienced it since update.. try reset your device
  14. soulfuleyes , via OnePlus 7 Mirror Gray , Jul 13, 2020 :
    I know that it is in july patch but its should be released in that month as OnePlus promise to provide regular updates. Also what about one hand mode?
  15. Fererio
    Fererio , via OnePlus 7 Mirror Gray , Jul 13, 2020 :
    This is July not August
    And about one handed mode it is probably not yet optimised. They will release it in the upcoming builds
  16. Fererio
  17. rpkkiran
    Froyo Jul 13, 2020
    rpkkiran , via OnePlus 7 Pro , Jul 13, 2020 :
    Yeah this beta's battery optimization is utter trash. My standby battery drain over 14 hours was 17%. All power consuming options turned off and network reception in my area is perfectly fine.. no issue with that guaranteed.
  18. Python_Dev
    Eclair Jul 13, 2020
  19. Arluy
    Arluy , via OnePlus 7 , Jul 13, 2020 :
    I'm currently using Open beta 16 on my oneplus 7. It will flash a bright white light everytime the screen turns off. Anyone facing the same issue?
  20. Rahulvitul
